Old 12-30-2012, 10:02 PM   #1
carney93
carney93's Avatar
Question Frickin bug!!!
I've had this bug in my truck for bout 1.5-2 years and haven't found it yet. When you give it some gas it starts stalling and sometimes it dies, mostly from a stop or if at a slow speed and go to pick up speed. Here's a list of things that have been replaced,
Rebuilt throttle with new seals and injectors
New IAC valve
New ICM
New Plugs, wires, cap, rotor
New fuel pump
New fuel filter
New map sensor
New pick up coil
And still haven't found it yet, anybody have any ideas as to what it could be?
Money<Time+Trucks
carney93 is offline   Reply With Quote
Old 12-30-2012, 11:45 PM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: Frickin bug!!!
Seems like you covered the most likely bugs. Is this when its cold or does it happen after its warm also? Also check the steering column, I had trouble with a short in the tilt steering that would make it die also.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 12-31-2012, 12:55 AM   #3
carney93
carney93's Avatar
Re: Frickin bug!!!
It happens when it's warm too. I know I kept blowing horn fuses when I'd try to put a new one in, they would pop before they were all the way in, but I don't know if its grounding in the column or somewhere else.
Edit: the only thing that I cant remember if it was replaced or not is the fuel pressure regulator, I remember getting one but not changing it.
Money<Time+Trucks
Old 12-31-2012, 06:05 AM   #4
tobiahr
tobiahr's Avatar
Re: Frickin bug!!!
+1 to this...the horn blowing fuses is also a sign you may have severe steering column wiring issues. i had a pickup that would stall everytime my wife drove it but would run fine when i did. i let her drive to show me and it turned out it was her 3 pound key ring. i used a single key when i drove with no key ring...the weight of her keys would shift and a loose ignition caused it to stall whenever she accelerated hard.
tobiahr is offline   Reply With Quote
Old 12-31-2012, 07:35 PM   #5
carney93
carney93's Avatar
Re: Frickin bug!!!
Would I be able to swap in a 73-87 steering column since my truck has cruise control and the wiper blade adjustments on it, or would I have to use a 88-98 column (if it will even fit)?
Money<Time+Trucks
Old 01-08-2013, 03:26 AM   #6
leftybass209
leftybass209's Avatar
Re: Frickin bug!!!
Seeing as you've replaced almost everything concerning the fuel system, there are just a couple places left to look. You can check for debris in the fuel tank, and or the fuel lines. Re check your fuel filter, but even if there isn't anything in it, doesn't mean you don't have a solid blockage inside the fuel line causing a starving fuel issue on demand. Also, check for vacuum leaks! Vacuum leaks can cause some really frustrating issues. It could be a hose, or around the manifold. Those are a couple places you could start. Good luck in your search.
leftybass209 is offline   Reply With Quote
Old 01-08-2013, 06:52 PM   #7
68Timber
I know the pieces fit
68Timber's Avatar
Re: Frickin bug!!!
You can still get a good one on ebay easily, just make of the year and stalk so it'll match up.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-09-2013, 10:32 AM   #8
onedayjake
Re: Frickin bug!!!
I would also check the pick up in the distributor. Pull the distributor cap off and look at the base and the pick up. If it's rusty it could cause you trouble, I've had a bunch of these go bad. A new distributor is pretty cheap at the parts store.
1947 1/2 ton, 5.3, 4L60E, 10 bolt
1974 Jimmy, 4 inch lift, 35" Thornbirds sold
onedayjake is offline   Reply With Quote
Old 01-09-2013, 10:46 AM   #9
Jonboy
Slots go on anything!
Re: Frickin bug!!!
Did you clean or replace the EGR? A clogged EGR will cause an off idle stumble.
A far as the column, any coulmn 84- up should work.
Jonboy is offline   Reply With Quote
Old 01-13-2013, 02:00 AM   #10
carney93
carney93's Avatar
Re: Frickin bug!!!
A friend of mine said to check the EGR valve too. I guess I'll do that before I think about the column.
Money<Time+Trucks
