02-13-2013, 06:10 PM | #1 |
Got my numbers to beat
Friend of mine dynod his '77 K10 Cheyenne and it made 410 hp and 450 ft/lbs torque. I'm gonna try and top it when I rebuild the 350 in my truck
Money<Time+Trucks |
02-13-2013, 09:31 PM | #2 |
Low & Fast!
Re: Got my numbers to beat
Thats big HP he is running....
02-13-2013, 09:57 PM | #3 |
I know the pieces fit
Yeah it is. Specs? A friend has a dyno and said he'd run mine in and make a few pulls to see what it will do. Not sure I want to know, his dyno is nicknamed the heartbreaker. What are you building?
02-14-2013, 01:27 AM | #4 | |
Money<Time+Trucks |
02-14-2013, 08:20 AM | #5 |
Sounds similar to an engine I'm building. Is this going in one of your Z's? I knew they went in 240's pretty easily but haven't seen one in a 300 before.
02-14-2013, 08:38 AM | #6 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-14-2013, 10:21 AM | #7 | |
Money<Time+Trucks |
02-14-2013, 10:23 AM | #8 |
As far as I know, it's rear wheel hp.
Money<Time+Trucks |
02-14-2013, 10:25 AM | #9 |
skip the glasspacks for power....there are a lot better flowing mufflers out there that make as much or more noise.
410hp/450ftlbs (500hp at the crank factoring an 18% dt loss) at the wheels is pretty stout, that costs a lot of $$. if you want to make power, a cam like the thumper really isn't going to get you there, they sound cool, but aren't really designed for big numbers. also, a thumper cam and the tpi will be very difficult to tune. John, we had a dyno at the junior college where I grew up, nicknamed the same thing! there were a lot of sad faces pulling out of that bay...haha
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop Last edited by OutlawDrifter; 02-14-2013 at 10:36 AM. |
02-14-2013, 12:57 PM | #10 | |
Money<Time+Trucks |
02-14-2013, 01:20 PM | #11 |
it may look straight through, but thats not how it flows. think of a glasspack as a backwards funnel, as all that air expands, then it has to restrict back down to go through the exit. it creates its own bottleneck. there is a pretty in depth science to creating an optimum exhaust system, its based on scavenging exhaust gases rather than just big pipes.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
02-14-2013, 02:34 PM | #12 |
You got me there, never thought of it like that. I was also thinking about using Hooker Aerochambers or Moroso Spiral-Flows.
Money<Time+Trucks |
02-14-2013, 03:18 PM | #13 |
go for the aerochambers, they sound great and have an expansion chamber in them to reduce the in-cab drone. i have an aerochamber on my ls powered z/28.
