04-22-2013, 11:47 PM | #1 |
shocks for a bagged truck
What kind of shocks should I run when I bag my truck? I was looking at the belltech nitro sport truck drop shocks 2 or whatever for the front and rear, but im assuming I should just by the ones that are suggested for the biggest drop right? Or is there a way i should measure my set up to figure out what kind to get?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
04-23-2013, 01:10 AM | #2 |
Square
Re: shocks for a bagged truck
your shock needs to have as much travel as your bags. I like the Toxic shocks, they are cheap and proven.
Squarebody Syndicate |
04-23-2013, 10:45 PM | #3 |
low n' slo
Depends on how low ur going too...
I used 1950 chrysler imperial shocks. Extended/collapsed height worked perfect and both sides have the "eye" style ends to run a bolt through like stock shocks Posted via Mobile Device
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
04-24-2013, 10:29 AM | #4 |
I would suggest shock extenders when bagging. If you keep the stock location, you need a really short shock to be able to collapse all the way when aired out. This will limit your up travel as well. A drop shock will not collapse all the way if you are bagging a truck using this stock upper shock location.
Best way is to get a relocation bracket, such as a Porterbuilt. |
04-24-2013, 12:03 PM | #5 | |
04-27-2013, 11:06 AM | #6 | |
Posted via Mobile Device |
04-29-2013, 01:15 PM | #7 |
The part# C10SRB
04-29-2013, 02:34 PM | #8 |
Is there someone that makes one of those but has a stud on it so you can use the stock eye/eye shock?..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
04-29-2013, 02:40 PM | #9 |
Yes, they make one, but it is taller because it is used for the Dropmember trucks.
04-29-2013, 02:43 PM | #10 |
Yeah those are tall.. probabky just end up makong my own.. lol
05-03-2013, 08:55 AM | #11 |
For something on the cheap, these are the factory 73-87 mounts cut off the rear end housing used with 1980s Jeep CJ5 rear shocks on the front of an 85 C10.
