Old 10-10-2018, 09:13 PM   #1
blazer2007
How stiff should the fr. u-joint new ?
I got a new u-joint installed on my fr. yolk on the driveshaft on a turbo 350, 2 wheel drive . I took the driveshaft out and took it to a shop to get installed , It seems tight to me but it says is normal ,I don,t thinks so .Is greased but it seems to be tight . I can move it around with no binding but it feels like there is too much pressure on the cups. Any idea on what a new u-joint should feel like. I couldn,t find anything on u-tube. Should the u-joint flop around or have some stiffness.
blazer2007 is online now   Reply With Quote
Old 10-11-2018, 06:27 AM   #2
PGSigns
PGSigns's Avatar
Re: How stiff should the fr. u-joint new ?
What I do when I get done putting the clips in is smack the yolk with a hammer in a way that seats the cups out against the clips. That tiny bit usually does the trick.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-11-2018, 03:50 PM   #3
blazer2007
Well was almost 0 Celsius this morning and wiggled the yoke and was super stiff ,not acceptable ,so did some strategic hammering on u joint and drive shaft here and there ,back and forth and got it nice but I had to file the c-clips a little .
Old 10-12-2018, 11:09 PM   #4
Ewr101
Ewr101's Avatar
When I did mine, the u-joints came with different width c-clips. I didn't realize this until I was finished and checked for binding. I was able to get rid of some of the binding by tapping the weld on the driveshaft but still ended up changing either one or both c-clips, I can't remember, to get it where I was comfortable finishing the install.
72 Chevy 2WD Blazer
Ewr101 is offline   Reply With Quote
