Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 02-17-2014, 06:50 PM   #1
SparkyRnD
SparkyRnD's Avatar
RnD Fabrication 1973-1987 Chevrolet & GMC C10 / C20 / Suburban Radiators!
RnD Fabrication is proud to introduce our line of 1973-1987 Chevrolet & GMC C10 / C20 / Suburban Radiators! We can build these for stock engines, as well as for LS & other engine conversions with ports in the correct locations for your engine. All units include a transmission cooler at no additional charge (specify when ordering). If you want one for an LS conversion, there is no additional charge, and simply specify if you want the steam port or not. Retail price is $530, and members of this forum get a discounted price of $505.
Here is a link to the 73-87 C10 page on our website:
http://www.rndfabrication.com/C10late.html
Make sure to mention you are a member to get your discount!
Also, we make them for 1963-1966 and 1967-1972 models as well! Contact us if you have any questions. Remember, we are a Gold Site Vendor and we offer discounts for forum members.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 02-20-2014, 12:30 PM   #2
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1973-1987 Chevrolet & GMC C10 / C20 / Suburban Radiators!
If you have an LS conversion, we make them with the correct inlet, outlet and steam port at no additional charge!
Old 03-06-2014, 09:07 AM   #3
SparkyRnD
SparkyRnD's Avatar
back up top, thanks for the support! Remember to ask for your discount when ordering!
Old 03-28-2014, 11:40 AM   #4
SparkyRnD
SparkyRnD's Avatar
bringing around again, let us know how we can help with your project!
Old 04-17-2014, 09:23 AM   #5
SparkyRnD
SparkyRnD's Avatar
back up again
Old 04-27-2014, 02:15 PM   #6
SparkyRnD
SparkyRnD's Avatar
up top again
Old 04-28-2014, 01:34 PM   #7
chevy-fun
chevy-fun's Avatar
can you tell me the dimension. an is this a 2,3,4 core?
chevy-fun is offline   Reply With Quote
Old 04-29-2014, 09:19 AM   #8
SparkyRnD
SparkyRnD's Avatar
These are based on the stock original radiators, and they are made with dual 1" thick cores for a total core thickness of 2". This is the same thickness as the old brass & copper 4-core (brass & copper units use 1/2" thick cores, where-as aluminum radiators use 1" thick cores). They are a complete bolt-in radiator, no cutting required.
Old 05-13-2014, 08:33 AM   #9
SparkyRnD
SparkyRnD's Avatar
back up top, remember to mention that you are a forum member to get your discount!
Old 05-22-2014, 09:15 AM   #10
SparkyRnD
SparkyRnD's Avatar
thanks again for the orders, and contact us if you have any questions
Old 06-13-2014, 09:04 AM   #11
SparkyRnD
SparkyRnD's Avatar
back up again
Old 06-25-2014, 03:34 PM   #12
SparkyRnD
SparkyRnD's Avatar
up top
Old 07-01-2014, 09:46 AM   #13
SparkyRnD
SparkyRnD's Avatar
We will be closed on Friday in observance of the 4th of July. Thanks again for the support!
Old 07-24-2014, 06:12 PM   #14
SparkyRnD
SparkyRnD's Avatar
back up again
Old 08-05-2014, 10:38 AM   #15
SparkyRnD
SparkyRnD's Avatar
Back up again, remember to ask for your discount when ordering (or tell us you found us here)
Old 08-12-2014, 01:36 PM   #16
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 09-05-2014, 12:02 PM   #17
SparkyRnD
SparkyRnD's Avatar
Contact us to keep your truck cool!
Old 10-05-2014, 08:48 AM   #18
haybale
haybale's Avatar
What brand are the fans? I'm looking at a complete kit sometime in the near future. Thank You
haybale is offline   Reply With Quote
Old 10-06-2014, 05:54 PM   #19
SparkyRnD
SparkyRnD's Avatar
the standard fans are private label fans we have made for us. We also can get Derale, Spal, and several others depending on what your budget / needs are. The more power you make and the less space available, the more they cost as a general rule. But with the C10's, there is a ton of room so our standard fans are usually more than adequate. If the engine is built, we just need details about the build / use of the truck to know what to recommend.
Old 10-06-2014, 06:38 PM   #20
flashed
Do you have a fan that mounts on the outside of the radiator on an A/C truck ,1972 ?
flashed is offline   Reply With Quote
Old 10-07-2014, 08:37 AM   #21
SparkyRnD
SparkyRnD's Avatar
All of our fans can be mounted as a pusher or a puller. What state are you in, and is your engine an sbc, bbc or ls? Stock or built? How much space do you have in front of the radiator?
Old 10-07-2014, 09:07 AM   #22
flashed
I am in Canton Ga not far from you ,I can bring the truck down for you to see what fits if needed .I wish I had known about you before I bought my radiator .
Old 10-08-2014, 08:53 AM   #23
SparkyRnD
SparkyRnD's Avatar
just a tape measure distance from the front of the rad to the nearest item in front of it will work
Old 11-03-2014, 09:09 AM   #24
SparkyRnD
SparkyRnD's Avatar
thanks again for the support guys, and let us know if we can help on your project!
Old 11-13-2014, 12:43 PM   #25
SparkyRnD
SparkyRnD's Avatar
back up top
radiator, rnd, rnd fabrication, rnd radiator
