Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-08-2017, 02:07 PM   #1
Harleymike
painting up side down
Was just looking over things and thinking. I have a question.
How do I use a gravity spray gun to paint the inside cab roof. It would be upside down.
I have an old cheap gravity feed, I could use just for the cab roof I suppose.
Any thoughts, thanks.
Mike
Harleymike is offline   Reply With Quote
Old 11-08-2017, 02:24 PM   #2
MARTINSR
MARTINSR's Avatar
Re: painting up side down
Mike
If you hold the gun at an angle with it full you can paint up there, it's not the perfect pattern but it's not a super critical place either. But yeah, you can do it.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-08-2017, 02:40 PM   #3
Harleymike
Brian
OK, ya I suppose it doesn't have to be perfect. No one will really look there.
Old 11-08-2017, 09:07 PM   #4
kxmotox247
kxmotox247's Avatar
Using a system like this will allow you to spray in any position. This is the devilbiss system but there are others out there.
http://www.tcpglobal.com/DEV-DPC-STA...l#.WgOppWeWxdc
The gun will behave a little differently with the system in place.
kxmotox247 is offline   Reply With Quote
Old 11-08-2017, 09:24 PM   #5
Foot Stomper
Foot Stomper's Avatar
Actually, the gun isn't really up side down if you think about it.
It's actually at a 90 degree to the panel most of the time so when spraying the roof, it could even be at less than a 90 degree...like 60 degree which still will allow the paint to flow.
To make my point, imagine painting a panel that is level with the floor, it's not really much different that painting the inside of the cab roof.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 11-09-2017, 12:51 AM   #6
sprint_9
sprint_9's Avatar
Im using PPS cups, they work pretty good for upside down and sideways. I found myself spraying sideways more than I thought I would, with a cup system you just go and dont worry about it.
sprint_9 is offline   Reply With Quote
Old 11-09-2017, 06:43 PM   #7
72HuggerK20
PPS cups are the best thing invented for painters. I was skeptical at first. They're worth the investment. You can spray at any angle, they're easy to clean up, they're quick, you don't need mixing cups anymore, etc.
72HuggerK20 is offline   Reply With Quote
Old 11-09-2017, 07:10 PM   #8
Foot Stomper
Only problem with using a suction gun is that PPS does not fit the gun.
Old 11-09-2017, 07:19 PM   #9
72HuggerK20
That's not the only problem with suction guns, I might add. Do they put paint on the panel? Sure. Can you lay it down smooth? Sure. Will you waste half or more of your paint by making it into a cloud? Absolutely. They're yesterday's technology, plain and simple. I get it if you only paint a car every couple years and you've had a suction gun for 30 years that works for you. Today though, for painting cars, buying a new suction gun would be my last choice.
Also, OP wants to use a gravity gun, so PPS or Devilbiss cups will work.
I'd recommend that he get one of the starter kits off amazon and an adaptor for his gun just to see how he likes them.
