05-01-2015, 10:15 AM | #1 |
76 c10 on 86 cab issues
Hey fellas found some topics similar but dance around my question. I have a 76 c10 and I replaced the old cab because of rust. I have an 86 on it now but I have encountered a new issues.
1. 86 column wiper wires and trying to use 76 wiper motor. Things just aren't working right when I use the controls on the column. Thinking I need an 80s wiper motor? 2. Light panel/dash mismatch- these are no aligning right. I thought they were backwards compatible with the metal dash frame being the same? So my plan is to remove the old dash from my 76 and replace the 86. I'm a sucker for the old style dash. 3. Hood support pins- they support the back of the hood to rest on when it's closed. It doesn't look like there is a place to screw my old ones in, I think I'll have to measure and drill? 4. Fenders don't really match the cab angles around the lower windshield. The top bolt is a tight squeeze to install it with the fender hole aligning to the cab. I'll try and get some pictures later today. I haven't played with the shims too much yet but I am wondering if anyone else has had this issue? I appreciate your help, I always heard the cabs where backwards compatible but these little issues I must of overlooked.
Andrew 1953 3100 292 T5 1985 K5 Blazer 350 700R4 208 |
05-02-2015, 10:53 AM | #2 |
Re: 76 c10 on 86 cab issues
No one ever upgraded their wiper or changed out their cab?
05-02-2015, 12:55 PM | #3 |
The 86 body does not use rear hood bumpers/supports. The 81 up hinges provide the support.
If I remember right you'll have to upgrade the wiper motor to a 79 or up. There was a design change right around that time.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
05-04-2015, 07:23 AM | #4 |
Ok thanks for the wiper tip I'll have to see if a newer one works. I wasn't sure.
05-04-2015, 09:10 AM | #5 |
85 and newer has the windshield washer pump in the reservoir. I don't know if that causes problems. Also, I see a lot of these trucks where the fender angle looks off from the windshield.
05-04-2015, 09:49 AM | #6 |
Ya I have that weird angle by the windshield too. Tempted to try and fab it to look better but I'm gonna be patient and see if shims can fix it. Lol
