12-09-2017, 01:47 AM | #1 |
My K10 turns sharper to the left than to the right.
Hey all, my '72 K10 turns much sharper to the left than the right..Drag link adjustment? Maybe the drag link adjustment?
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
12-09-2017, 08:01 AM | #2 |
Re: My K10 turns sharper to the left than to the right.
Sounds like it. Do you have a lift on it?
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
12-09-2017, 10:50 AM | #3 |
Yes it has a 4" with a dropped pitman installed by PO...I assume it's the right one drag link is level..
12-09-2017, 11:38 AM | #4 |
I had the same issue when I purchased my truck. I found it necessary to adjust the wheel stops, then center the box, set the toe and steer ahead. My truck drives normal now.
12-09-2017, 03:23 PM | #5 |
All of my K-10's I've had over the years have always been like that, my 64 that I have now turns sharper to the right then left...Even my Dad's 71 GMC also was like that, he didn't have a lift on it...
1964 BBC 402 4x4 |
12-10-2017, 08:54 PM | #6 |
You've probably already done this, but if not.... take the steering damper off, then test and adjust other components. An incorrect or incorrectly mounted damper will do/cause this too.
j
White K20 |
12-23-2017, 02:08 PM | #7 |
Fixed.
Replaced both ends of the drag link as the steering box end had quite a bit of play. Parked truck with wheels straight. Disconnected the drag link and turned steering wheel lock to lock a few times. Got about 4 turns. Turned steering wheel 2 turns and made the drag link fit...had to lengthen it about 2". Bolted everything down and went around the block. Truck turns about the same left and right now. Pulled off my Astro Van steering wheel and adjusted it to centre. It was really hard to park in the parking lots made for subarus and pries's. Seems to be good now.
