![]() Join Date: Jan 2012
This is MY rifle.There are many others like it but this one is MINE. Beware the man who only owns 1 rifle , he probably knows how to use it. |
![]() Join Date: Nov 2004
Re: get in line
Have you had the frame checked yet?
Core support, outer finder, inner fender, hood, grille, bumper.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Re: get in line
Use an X measurement to make things simple. Put on the core support, then find a common point on the right front[say the bolt hole that the fender triangle bolts to] and the cowl vent bolt on the left rear. Tape measure ti and get the number. Then go to the SAME points opposite side then read the tape.
The idea here is to get them as close as possible to the same number. That will mean the core support is Square to the cab that way the fender [and hood] will align MUCH better. Then you can go about hanging the fenders then inners . Hood goes on then grille and bumper. If you get the measurement right on the fenders[X] you can bolt in the grille right after the fenders if you want it will be fine. that way if you have to wait on friends to help with the hood you can make progress until they show up. |
67ChevyRedneck , i have not had the frame checked . are there any things in particular that i may be able to check myself ? thanks , kenny
Re: get in line
Read my post. The X measurement can be used for anything, it is the MAIN way to check real fast if a frame is square or just the front or the bed anything you can figure on can use the X method to check it out. Like on the frame go against the crossmember on the drivers side then go to the frame horn on thew pass side. Read the tape then do opposite from the same spot and it will tell you if the frame is tweaked
hugger6933 , thanks for the info . i have read and printed to save for future referance . thanks again, kenny
