06-01-2017, 06:37 PM | #1 |
Replacing windshield trim w/o removing windshield?
You can see in the pic that my chrome windshield trim is looking roached. I see that LMC sells just the chrome trim piece and would like to swap it out. Is it possible to swap out without having to remove the windshield? If so any tips? Thanks!
06-01-2017, 08:23 PM | #2 |
Re: Replacing windshield trim w/o removing windshield?
Yep!
That's the last thing that is put in place. It's called a "locking strip" it pulls right out, they make a tool to put it in. Enjoy, |
06-01-2017, 08:34 PM | #3 |
06-01-2017, 08:56 PM | #4 | |
Thanks.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
06-01-2017, 09:21 PM | #5 |
My gasket set from lmc came with one like this..
06-01-2017, 09:25 PM | #6 |
Here it is..stick "a" and lock strip installing tool.http://www.lmctruck.com/icatalog/cc/full.aspx?Page=35
06-02-2017, 12:17 PM | #7 |
Alternately this tool is very easy to use and it follows the trim around quite easily. The only thing to remember when installing these trim strips is you don't want to stretch it. I found the easiest way to prevent that was to stop periodically and push the trim back against itself (if that makes sense) as the trim will shrink somewhat over time. Here's is a description to put into your browser, I am not sure if the link is cool to post AllGlassPartslockingstriptool
06-02-2017, 12:17 PM | #8 | |
06-02-2017, 12:38 PM | #9 |
I done mine last week , super easy with that tool. Ive got one for the back window ordered now!
1980 Silverado short bed 1993 GMC 1500 LS swap 2006 Lifted Z71 Crew Cab |
06-02-2017, 01:43 PM | #10 |
dang i never knew they made a tool for that, i always just used a screw driver with a bunch of soapy water to make it go in easier
06-02-2017, 01:48 PM | #11 |
Me too. Plastic windshield tool is less aggressive on the rubber though
06-02-2017, 09:55 PM | #12 |
At O'Reilly part number 47000 made in the USA.
Use soapy water. |
06-02-2017, 10:00 PM | #13 |
06-02-2017, 10:10 PM | #14 |
Is the tool
