Old 01-19-2018, 04:55 PM   #1
amerskier
55-59 TCI under cab brake booster
Looking to see if any of you have installed this unit on your trucks and if you had an alignment issue with the original hole in the firewall for the pedal. Mine is roughly an inch and a half off center to the outboard side of the hole.
amerskier is offline   Reply With Quote
Old 01-19-2018, 05:03 PM   #2
amerskier
Re: 55-59 TCI under cab brake booster
Picture of unit
Old 01-19-2018, 05:38 PM   #3
jkmhb
I bought mine off ebay, did not say TCI brand, but fits perfectly.
1958 Chevy Short Fleetside - 350 Stealth Ram FI/700R4/Old Air
1965 Corvette Convertible 350/Richmond 5-speed
jkmhb is offline   Reply With Quote
Old 01-19-2018, 06:00 PM   #4
sack54
I had a problem like yours, but not 1 1/2 only a half . I ended up leaving the adapter piece off that goes to pedal . Used a large washer for shim to center arm hole . Then used the original hole in the arm, and made connection, Works great ! Also shimmed ,with washers behind the mount plate
sack54 is offline   Reply With Quote
Old 01-19-2018, 06:51 PM   #5
amerskier
Thanks for the reply. Not sure why it is so far away from center. I could work with half inch but inch and a half means completely rebuilding the arm. Checked cab being squared up to frame.
Old 01-19-2018, 07:33 PM   #6
sack54
Do you have the stock brake pedal arm. it should be the same, you could try it should fit
Old 01-19-2018, 07:49 PM   #7
sack54
You could make a spacer and mount the unit to the spacer .
Some nice thick round stock and a plate and stiffener arm from the inside bolt on the boaster to the frame. this will make it stay ridged while applying the brakes.
Old 01-19-2018, 09:06 PM   #8
amerskier
sack54 unfortunately I do not have the stock pedal or the original master cylinder. The original mounting bracket that was riveted to the frame was gone so I was lucky enough to get one from a member on the site. Pretty sure it was from a 57 truck so it should be the same as my 56.
Old 01-20-2018, 05:12 PM   #9
sack54
I will measure my mount for you my truck is a 56 GMC
Old 01-20-2018, 05:59 PM   #10
amerskier
Sack54 thanks that would be great!
Old 01-21-2018, 05:19 PM   #11
sack54
Checked it out today for you, from the frame out measures 3 7/8 to top of mount
Old 01-22-2018, 02:33 PM   #12
amerskier
Sack54...Thanks for taking the time to measure for me.
