60-66 Nut
Gear Ratio Match Up
I'm helping a friend gather parts and install a 10 bolt front and 14 bolt rear under his Blazer. The 10 bolt front has 4.10 gears. The first 14 bolt we pulled has 3.73's so the search began for another with 4.10 gears. I found a early '80's G20 or G30 with a 14 bolt, but it has 4.09 gears. I had never heard of such gears for a 14 bolt, but in doing some research, it seems that is a common gear used in the G series vans. So my question is, has anyone used a 4.10 front gear with a 4.09 rear gear? I know that is backwards from the normal ratio match up, but I don't know how it will act with the rear wanting to push a little.
![]() Join Date: Mar 2003
Re: Gear Ratio Match Up
Match up is correct, won't hurt a thing
I've used 2 of the van rears now with no issues. But I thought when I checked they were 4.11.....either way not enough of a difference.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
For off road it's fine as there's enough tire slip for the slight mismatch not to matter
60-66 Nut
Thanks for the replies guys. I thought it should be fine but since the ratios are the opposite of how they should be, I just wanted some input from those that may have done the same thing.
Pretty sure thats what I have in the '63 now with the Dana 44 and the 14B rear. Works great.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Agreed, and in fact I never engage the front axle on pavement anyway..... only when 4WD is called for, on a loose surface so the tires can slip.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Feb 2007
The rule of gear matching is as long as they are within 4% of each other you're good.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
4%?? Try 1%.
Well ideally rat yes, but industry standards from the '60's through the '90's, solid axle eras, had a 4% leeway.
Only vehicle I can recall that had a "major" difference was early Bronco's. I had a set of axles that were 3.54 front Dana 44, and 9" rear had 3.50s. Even that is 1% IIRC.
Yep, the spread wasn't big but they still said up to 4% was approved. Chev's had 4.09-4.11 difference in applications.. Jeeps had a 4.07-4.11 spread. Dodge had a few too that was 3 10th's difference. Heck tire pressure difference between the front and rear can create more than 1% ratio difference with just a couple psi. That's why tires can be considered as variable gearing devices.
6>8 Plugless........
![]() Join Date: Sep 2007
A lot on here would be surprised by the difference in gearing on pulling trucks front to rear.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#14 | |
Check out those mud pit runners and their gear and tire size differences. Super cool!
#15 |
1% or 4% one thing is for sure... Its 100% harder to disengage 4wd on dry pavement for the unlucky moron that doesn't believe what everyone says about using 4wd for "4wd conditions". Its just as hard to do the second time since I didn't learn from the first
![]() One thing I do miss about a couple of the last trucks that I did have was the ability to "shift on the fly" while driving in snow or ice. I think those trucks had Borg Warner t cases and there must have been some sort of "differential" type mechanism to them that allowed this? I haven't tried it with my current 205. I always stop to shift. Does anyone here run with hubs locked and shift while moving at more than creep speed?
#16 |
I was doing 4x conversions in the late 70s and early 80 where the rear was 3.64 ratio and the front we put in had 3.54. Never had any complaints about the difference of 3% 3.54/3.64= .972 or 2.8%
#17 | |
Shift on the fly trucks have a transfer case with a synchronizer like a manual transmission. Many makers have them. I think some of the late NP205's were synchronized.
#18 |
My 61 k10 has 3.38's rear and 3.31's in the ft dana 44. stock was 3.90 and 3.92 ft. No problems with this set-up on dirt/snow. Don't think i would run it on payment though.
1961 chevy K10 my build is------------61K10 build |
#19 |
60-66 Nut
Just to clarify, I am completely aware of the typical gear ratio split between the front and rear differential. I have dealt with several 4x4's over the past 40+ years. my concern was with having the 4.09 gears in the rear and 4.10's in the front instead of the 4.09 in the front and 4.10's in the rear.
#20 |
That's perfectly fine. Easily close enough match. You have nothing to worry about.
