01-29-2018, 02:11 AM | #1 |
"Basics of Basics" Removing rusty bolts.
Removing rusted bolt basics
One of the first jobs I ever had was at a shop doing full on restorations on vintage Fords (we specialized in model 40s 1933-34). By boss taught me MANY things I use every day. One of them was the best trick for getting rusted bolts out that I have ever tried. You need your torch with a small tip. Take the torch and make a perfect flame like you are going to weld. Heat the bolt head up till it starts to turn red. (If the bolt is already broken off you will need to saw a grove to use a flat blade screwdriver or have enough to grab with locking pliers) Then quickly cool it with a squirt bottle of water. Repeat, heat it, then cool it. Do this a number of times and the bolt WILL turn right out. If you can, heat the nut around the bolt right before you try turning it out, BUT DON'T HEAT THE BOLT. This will expand the nut from around the bolt. I have did this on Model A door hinges, if you are not familiar with them, it is a 5/16 bolt with a little flat blade screw driver head! A ridiculous design that rusted in to tight to remove around 1950! You can imagine how hard they are to remove in 2000. I have did these with total success, only needing a regular hand screw driver about 99% of the time. The way I figure the heating and cooling expands and contracts the screw breaking it loose from the rusts grip. Today I used this method and it worked so well, it was kinda sexy. This window frame from my 1948 Chevy pickup had 1/4" bolts that held it to the regulator. Those bolts were so rusted that they broke off trying to remove them. Photo 1: On the front side I ground off the mushroomed broken off end flush with the nut. Photo 2: The end of the bolt that was sticking out of the nut I made a "screw" out of it by cutting a slot with a hack saw. I then heated the bolt and the nut with the torch and then cooled it with a squirt bottle of water. I did this three times. Then just for fun I did the back side where I had ground flat the broken end of the bolt, just once and cooled it. Photo 3: I then turned right out without so much as a grunt with a hand screw driver! Man I have to thank my old boss from 1979 every time I use this trick, it is like magic! Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
01-29-2018, 07:34 AM | #2 |
Re: "Basics of Basics" Removing rusty bolts.
We used to use a bar of wax at the machine shop I worked at. Instead of water.
01-29-2018, 08:56 AM | #3 |
Tried the heat and wax thing wyself for first time on a rusted threaded able joint when I had broken a breaker bar with a 6ft extension.
Worked. Good tip on the repeat heat and cool .... Might try that one next time. Thanks
FAKKY 57 PANEL BUILD |
01-29-2018, 11:30 AM | #4 |
01-29-2018, 11:44 AM | #5 |
MARTINSR has some very good tips . I have used penetrant as it cools but often times gets burned up in the removal process . Beeswax seems to work better but really think the heat is the key.
I will put my torch against any penetrating oil I have ever used. In fact I am running propane(cheaper than aceytelen for cutting) and oxygen for cutting and still use that cutting head to loosen screws and bolts. You just have to be more careful and adjust your flame to mimic a small brazing tip flame. Big bolts you might need a rosebud. Also if you have one that is really stubborn I will not let the screw or bolt cool . Torch in one hand , screwdriver or wrench in the other. I have had several screws freeze back up as the red heat went away. Simply reheat and repeat. Also another little tip. Spray the frozen part with penetrant. I then take it to my cabinet blaster and bast any threads that could be showing . It removes the few thousands of rust that build on to it. If you want some great tips talk to a mechanic that removes broken head and exhaust bolts from heads . You can actually take a small bolt and weld it to the broken bolt , heat and remove. They have many other tricks also. My machinist is almost 70 years old . He should write down all the secrets he learned in the last 50+ years. It would be a thick book but a great read.. Last edited by paulspickupparts; 01-29-2018 at 11:58 AM. Reason: speeling ha |
01-29-2018, 07:18 PM | #6 |
That works pretty well, sometimes just heating either the bolt or nut red hot and letting it cool burns out the rust and makes life easier.
01-30-2018, 10:57 AM | #7 |
Most of the time I just MIG weld a nut on broken bolt,it might take a couple tryies,next time I will use your cool down method,water or bees wax
01-30-2018, 11:29 AM | #8 |
They are all options, the point being you CAN get rusty bolts out. I have welded nuts on bolts too, but there are other options when that can't be done.
Brian
02-03-2018, 03:40 PM | #9 |
I've always used heat to remove frozen bolts, but the heat and cool is an interesting idea. I can't wait until I encounter my next rusted fastener.
02-04-2018, 01:22 AM | #10 |
Martinsr, this is a good tip for a topic that anyone working on old cars has to deal with eventually.
I have made it something of a specialty to successfully remove rusty fasteners. Vehicles in this part of the country are exposed to years of road salt, acid rain, and high humidity air and mechanics here have plenty of chances to practice if they want to be skilled at bolt removal. There are a *lot* of good tricks but knowing how rusted bolts get stuck is important. Since this is a "Basics of basics" thread maybe it would be good to explain it. When iron turns to rust it expands. Bolts left rusting for years can actually be larger than they started until the rust is removed. If a bolt and nut rust together the rust on the bolt will try to swell and split the nut while the rust in the nut will try to compress and grip the bolt. That fastener which was nice and loose years ago ends up being locked tight in a press fit. In order to get the bolt to spin the press fit must be broken be removing pressure. It can be important to know what types of metal you're working with. MARTINSR's tip is very good for many mild steel fasteners. Heating and cooling parts with a torch can cause several side effects. Some of the rust may burn off. Some of the rust may fall off and be blown away by the force from the torch flame, like air blowing dust. As the fastener and / or parts around it are changing dimension the bond between rust molecules can be broken. With a heat and fast quench on mild steel it's possible for the fastener's dimensions to actually be changed slightly after the part cools. With short screws and small nuts this simple heat/cool trick is often good enough to get the job done. Another version of this works great with fasteners in cast iron, especially pipe thread fasteners. Heat the fastener to red, walk away until it's nice and cool, then easily remove the offending part. It's important not to heat the cast, only the fastener. Not all applications can be heated. And heat doesn't always work alone. In many cases it's important to take a different approach or to add a second step: Remove as much rust out of the threads as possible. Rust is iron oxide. The molecules are abrasive and they are harder than most steel and cast. Trying to unscrew very rusty and dry fasteners causes the rust to scar the threads. What's worse is the pressure of the press fit combined with the abrasiveness of the rust creates heat at the area where the bolt or nut is turning. It's actually possible to create enough heat to weld the threads together! This is where a penetrating oil can really help. While some penetrating oils can actually break or loosen the bonds between rust molecules, the best use of penetrating oil is to provide a lubricant under the abrasive rust molecules and to flush rust away from the fastener. Don't be afraid to douse a severely rusted fastener with penetrant during removal. Use as much as needed. And combined with the oil, it's common to have to work fasteners back and forth several times during removal. Spray, turn spray, turn, back and forth. This helps flush out rust and it helps push penetrating oil back through the threads to push oil out the other side. In many cases a few repititions are enough to allow the fastener to move easily. In some cases you may not have heat, or the part may not be heatable. Repeated vibration can do wonders to break up rust. I have developed a technique using my air hammer and a mushroom bit so I can gently tap away at a rusted fastener to break up rust. Then I will use air and penetrating oil to blow garbage out of the threads. This can be followed by an attempt to move the fastener or more air gentle hammering. Sometimes turning an impact wrench down low can work. And I've even been known to tap, tap, tap away with a hammer on the head of a bolt when it's critical to remove a fastener without damaging the surrounding components. It also helps to develop a feel for what you're removing. Soft steel brake fittings in calipers or wheel cylinders are a great example of this. I spent years learning how to have more success than failures with these parts. Torching them often isn't an option. The trick is to get them to move ever so slightly then to work them back and forth using penetrant to flush the rust out. But you really have to develop a feel for how much pressure to use and how far the fittings want to turn before they try to sieze up again. I've found that a longer ratchet or wrench allows much more control over the torque applied. With a short wrench you usually crank 'em up pretty hard and there's no turning back if the fastener starts to break. Ultimately it may be necessary to drill out a bolt or stud and use an easy-out. This is where taking time to prepare pays dividends. Make sure you use a center punch to start the drill correctly. Use a sharp drill and make a pilot hole. Check to ensure the drill is drilling the hole straight through the bolt to start. It may be necessary to "walk" the hole to get it centered. Once the hole is drilled it's time for the easy out. I prefer fluted, drive-in types. I have one of these at work and one at home. The screw-in, tapered type don't seem to work as well. First, they try to expand the bolt into the hole as you tighten them. The goal is to reduce pressure! Second, they only grab the fastener at the outermost edge. This can allows them to and oblong the hole you worked so hard to drill. Third, driving the straight ones with a hammer in helps break up the rust. Love to hear more tips. As much as I know it's always good to hear more! Last edited by 1project2many; 02-04-2018 at 08:06 AM. |
02-04-2018, 01:38 AM | #11 |
Good additional info and ways to look at stuff.
Brian
