06-10-2018, 06:59 PM | #1 |
Hei dbl check ?
I know this has been covered to death but i just want to make sure. I m changing from points dist. To hei dist. I ve disconnected yellow wire from starter. Taped up yellow wire that used to go to neg. Side of coil. Ran correct gauge new wire from hei dizzy to fuze block. All correct ?
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
06-11-2018, 12:58 AM | #2 | |
Msgt USAF Ret
Re: Hei dbl check ?
You will want to run the wire to the IGN UNfused terminal on the fuse panel, which is fed by the ignition switch with key on. A 12 gauge wire is recommended. you meant the yellow wire went to the positive side of the coil. Here is a very nice alternative to wiring to the fuse panel as it directly replaces the ignition wire from the key switch to the ignition coil. http://67-72chevytrucks.com/vboard/s...d.php?t=708975
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
06-11-2018, 07:54 AM | #3 |
Re: Hei dbl check ?
Yes sir. Thank you. Just wanted confirmation before i burnt up a new dizzy. Should be starting new 350 next weekend. Finally.
