05-27-2018, 05:36 PM | #1 |
Wheel Studs for 69 Blazer
I picked up a set of the new Wheel Vintiques stock type steelies that are 15" X 8" with a 4 1/4: backset. Took one down to the body shop where the tub/chassis is and test fitted it on the front. It hits the tie rod end. I came home and got out a set of 1/4" wheel spacers. Went back over and tried them out with no rub on the tie rod end. Will need some studs that are about 3/8 " longer. Anyone know the exact specs of the original K5 studs so I can soures some new ones? Thanks
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 05-30-2018 at 10:20 AM. |
05-27-2018, 08:52 PM | #2 |
Re: Wheel Studs for 69 Blazer
First, don't use that wheel spacer as they are known to break studs. Here in Ontario, they are illegal to use. Second, if you're going through the hassle of replacing studs, scrap the 7/16 original ones and install 1/2-20 studs especially if you plan on using larger tires.
