09-11-2019, 06:37 PM | #1 |
Thanks for ALL the help
Hey guys I know many of you have helped a lot with all of my "FUEL" related drama.
Short story: I loaned my truck to a "friend" who was doing home renovations. He had the truck over a year and basically let it sit...under a tree. One tank ended up rusting out completely the other is beginning the process. This caused the fuel lines to degrade and subsequently the fuel pump and of course the carb. I replaced one of the tanks (the really bad one), the fuel pump, numerous lines and added a nice fuel filter to keep things clean. I could never get that Quadrajet running right, either with a store bought rebuild or my own. But I just bought a new Edelbrock 1405 (with Q-jet adapter plate) and the truck is running like a dream. It started right up. The only adjustment was the curb idle. I can't believe how much time I wasted with the Q-jet. So I wanted to say thanks for all the help. It was frustrating but I think I got the big stuff done. The one thing on my list that I do need to get done is the kickdown on the throttle linkage for the carb. What is the best way to adjust this? |
09-11-2019, 06:46 PM | #2 |
Re: Thanks for ALL the help
Depends what tranny you have!
09-11-2019, 06:57 PM | #3 |
09-11-2019, 07:00 PM | #4 |
Do you have a pic of the cable?
There are a couple different ones that are adjusted slightly differently. |
09-14-2019, 03:19 PM | #5 | |
http://www.chuckschevytruckpages.com/73-87specs.html Last edited by SilveradoDude; 09-14-2019 at 05:30 PM. |
09-14-2019, 04:15 PM | #6 |
Turbo 400 doesn’t have a cable.
09-14-2019, 05:22 PM | #7 |
09-14-2019, 05:37 PM | #8 |
That doesn’t mean much.
Take a pic of it. |
09-14-2019, 05:45 PM | #9 |
09-14-2019, 05:49 PM | #10 |
Yes I do know.
Turbo 350 has two styles. Pop up tee or push down button. Each adjusts differently. I could explain both but with a pic it makes it so much easier. |
