08-22-2018, 12:44 PM | #1 |
Power brake petal drop question
I have installed a stock power brake setup on my 68, and I don't have the engine running yet. I have bleed the brakes but the pedal will still go down slowly if I keep pressure on it. Is this normal with power brakes and no vacuum?
1968 SWB Step Side, Big Block, 4L80E , Running! |
08-22-2018, 01:38 PM | #2 |
Who Changed This?
Re: Power brake petal drop question
What all changed? Did you just add a booster and master? Do you have the shoes all adjusted to the drums?
08-22-2018, 02:07 PM | #3 |
Petal is very firm and doesn't go far down on the initial push, but with continued pressure it moves slowly down to the floor.
08-22-2018, 03:51 PM | #4 |
Who Changed This?
Is it the old master cylinder? That's a symptom of a bypassing piston, which indicates that it should be replaced or rebuilt.
08-22-2018, 07:38 PM | #5 |
Brand new. Its a 1 1/8" bore for power brakes. Took off my 1" bore manual brake master to install it.
08-22-2018, 07:40 PM | #6 |
laying low
The fluid is going somewhere. It's either bypassing inside the master or there is a leak somewhere.
08-23-2018, 12:01 PM | #7 |
I agree not right. Should hold up longer than your leg will. Either a leak in the system or a bad master cylinder
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
