![]() Join Date: Jan 2012
fuse panel question
I am working on a 1982 k30 and need to use a accesory switched 12volt plug on the fuse panel. did Gm make plugs that just plugged into the panel ? I tried to use a male spade just pushed into the socket, not happy with it. Thanks
Re: fuse panel question
Yes there should be at least one accy you can put a male spade.( that one is not Fused you have put in line fuse) What ever accy that close to it what ever fuse is in the that one is what the wire is rated at (witch I think is 15 or 10 so if it more your going to have use some thing eles.
but have to look at your fuse box. Make sure if it is . There might be a few fuse option not in use that you can make your connection to. Test light time. If your fuse box had A/c you might have a few. you can get jumper fuse contacts.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 08-22-2018 at 11:02 PM. |
![]() ![]() Join Date: Jan 2015
Yes they had accessory plugs that plugged into the fuse block with clips on them to lock them onto the block
Thanks for the help guys ! Jeff would you happen to have any of those plugs available?
I should have a few I'll look on Saturday and let you know as I just picked up 2 k/30 crew cabs
Go to www.repairconnector.com, and look at fuse taps and links on their menu. You'll find the tap and pigtail that you need for your fuse block
Moderator
![]() Join Date: Oct 2008
The 79 and later fuse panels used several different Pak Con connectors depending on what slot you wanted to use.
The slots were hot under different conditions. BAT, IGN, ACC-only, IGN/ACC, ... Get the GM wiring manual for your year. The connector part numbers and the function of each group of power taps are in the wiring manuals.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#8 | |
https://www.connectorpeople.com/Conn...ARD/1/12004892 I'm going to need 2 myself to wire in a headlights on buzzer. |
#9 | |
Moderator
http://67-72chevytrucks.com/vboard/s...d.php?t=729153
I looked and came up empty handed sorry
