03-28-2019, 09:11 AM | #1 |
1970 c20 disc brake swap
hello,
been trying to figure out if this can work. 1977 disc brake spindle from a g30, I replaced the "big disc" with a normal one had to change upper and lower ball joint longer hydraulic hose everything works to this point. spindle is mounted and moves freely. the point where I am a little bit curious is the steering. my 70 c20 got 5/8" tie rods (if i´m right?) the van spindle asks for a 11/16" tie rod. Is there any other solution than buying this super expensive hotchkis tie rod adapter sleeves where you can connect a 11/16 tie rod to a 5/8. remember that I´m from Europe. So shipping heavy and big parts like a spindle is very expensive. Last edited by sim; 03-28-2019 at 09:30 AM. |
04-01-2019, 03:43 PM | #2 |
Re: 1970 c20 disc brake swap
04-01-2019, 06:03 PM | #3 |
Really what are the odds that we would both be in the process of doing the same thing on a c20. I pulled up the forum, because I couldn't remember how the steering went.
1969 Chevrolet C20 Longbed I-6 250, SM465 |
04-04-2019, 08:19 AM | #4 |
have a machine shop open the taper in the drag link to run tie rods off the 77
77 SWB 2wd. gutted, caged, slicks, not weighed yet 02 Duramax CCSB 4x4 12.7@104 6750lbs |
04-06-2019, 04:22 AM | #5 |
@simon tek
Haha, even the same name! Thank you all. I've ordered the hotchkis tie rod adapters. I'll let you know if it works. |
