06-28-2019, 09:09 PM | #1 |
Will my rally wheels fit discs?
Hey all
Swapping over to front discs soon, and my truck has rallys (15x8), but I’m not 100% sure if discs will fit, I know there was a diagram somewhere comparing the old wheels and the newer rallys that fit. Pic of the inside of one of my wheels, I can go take the wheel off if it makes it easier to see Cheers! |
06-28-2019, 09:22 PM | #2 |
Re: Will my rally wheels fit discs?
Those AFAIK only came on disk break trucks.
06-28-2019, 09:43 PM | #3 |
That would be awesome if they are sweet! Just took the wheel off, here’s a better pic attached
06-29-2019, 12:04 AM | #4 |
60-66 Nut
Yes those 6 lug Rally wheels will work with disc brakes as long as you stay with stock size rotors which are just under 12" in diameter.
06-29-2019, 12:05 AM | #5 |
Mine does!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-29-2019, 12:46 AM | #6 |
Wicked!!!
I’ve just ordered these from Early Classics. Doesn’t say actual diameter, will drop them a line just to make sure https://www.earlyclassic.com/node/154 Cheers |
06-29-2019, 12:55 AM | #7 |
Just looked on their site and they are 12”
https://www.earlyclassic.com/taxonomy/term/72 Which is good! Thanks for the advice all! |
07-03-2019, 02:17 AM | #8 |
I have the Early Classic kit on my '63 with Rallys off a '78 Chevy. 15X8s. I havent had any problems
07-03-2019, 03:43 AM | #9 |
Wicked, thanks mate! Appreciate the reply
07-12-2019, 01:54 PM | #10 |
I had 86 Suburban rally wheels on my 65 Suburban. I had changed to 5 lug disc in the front, and traded chrome smoothies for them. At one time even had them painted the body color. With the chrome ring and center caps, it looked good.I started with the 6 lug version before I switched to the 5 lug
07-12-2019, 04:21 PM | #11 |
Here's my burb with the 5 lug 86 Suburban Rally wheels
07-14-2019, 06:20 PM | #12 |
I have 15 inch Rally's and my 12 inch rotors might have worked but I have the big GM dual piston calipers and they hit. Good Luck!
07-14-2019, 07:36 PM | #13 |
