01-10-2020, 05:18 PM | #1 |
t221 bearing and seal part #s
Does anyone have a list of part numbers for the bearings and seals for the rockwell t-case? I know torque king sells them all in a package but it seems like I could source them locally or at least from rockauto for less than $300.
01-10-2020, 08:49 PM | #2 |
Re: t221 bearing and seal part #s
We don't have a complete list of the bearings or seals yet, but we are going down the same road you are. We figured it would be cheaper going to the local parts store or ebay. Did a quick check and found some bearing on ebay (timkin) that were a lot cheaper than napa. We will have to check out rock auto. We did get some of seals at autozone(shift shaft) and the yoke seals. The case is out to get powdered coated and then reassemble.
01-11-2020, 02:01 AM | #3 |
01-12-2020, 11:11 AM | #4 | |
01-12-2020, 11:22 AM | #6 | |
01-12-2020, 05:40 PM | #7 |
If you don't mind, can you post when you get all your bearing. We would be interested if they are all correct. We are going to order some of are bearings next week. Thanks
01-13-2020, 06:03 PM | #8 |
Yes I will. I did notice though that I only ordered 1 shift seal and I need 2.
