04-18-2022, 08:37 AM | #1 |
K20/K30 front spring hangars?
Hi gang.
Got a nice 2wd C30 frame and cab I want to convert to a 4WD. Finally found a donor to use for the front bits. Any sources for replacement front leaf spring hangars? I can grind the rivets off the donor frame if needed and use those but I dont mind just buying new. Plan to keep it stock height, no lift. Internet search did not yield anything obvious. Krusty |
04-18-2022, 09:23 AM | #2 |
Re: K20/K30 front spring hangars?
If you've got a good set ,I'd just use them
I did a quick search and found a used set for sale..they wanted $250 for them
04-18-2022, 10:37 AM | #3 |
Roger that.....grinding rivets is not the best fun a guy could have but for 250.....I can suck it up!
04-18-2022, 07:28 PM | #4 |
Are there any buy new options? Not that it would save money. For those with no donor
04-18-2022, 08:41 PM | #5 |
Tim, I did see a some new fabbed mounts when I did my search..so they are out there
04-19-2022, 08:43 AM | #6 |
Somebody makes aftermarket ones. I can't remember who right now. Pirate 4x4, off road design? .....
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
04-19-2022, 09:55 AM | #7 |
6>8 Plugless........
I'm not sure if the stock ones are available new. Fabricated ones are for sure. I have some B52 ones for my square project if it ever sees light of day again.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-19-2022, 02:00 PM | #8 |
At the body shop.
https://www.offroaddesign.com/2wd-to...ucks-pair.html
These work? I just swapped a 4x4 k5 to a 2wd and the bolt pattern for the hangers where different
" That didnt make it any newer " " Dont antique the equipment " |
04-19-2022, 03:59 PM | #9 |
Here are the ORD's designed for 81-87 https://www.offroaddesign.com/replac...ucks-pair.html
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
