Old 04-11-2020, 11:08 AM   #1
72LB
72LB's Avatar
12 bolt carrier questions
I'm getting ready to put this back together but aren't sure on stacking the clutches. The kit has 3 clutches and 4 plates per side but from what I've read a clutch has to go against the back of the gear, is the extra plate not needed? It's alot smaller a stack for the clips without it too. Also the book I have says reuse the shims that were on each side, is that ok or would it be better to use the new shims from the kit?
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
