05-02-2020, 02:12 PM | #1 |
Removing front brakes, control arms, where do I start?
I’m wanting to replace everything back to including new control arms. I know I have to keep a jack under the control arms to keep pressure on the spring but where do I begin? What do I start taking off first? I’m new at this. Thanks for any help.
Phillip |
05-02-2020, 02:46 PM | #2 |
Re: Removing front brakes, control arms, where do I start?
The easiest way for us to help you is for you to watch some videos like this one and then you can return here with specific questions. The video linked is for a square body and has slightly different lower control arm mounting.
Be aware that the task you are looking to undertake is dangerous and has the potential to end your life if done incorrectly. I recommend you have someone experienced help you do this the first time. And strongly recommend that if that is not possible to have someone nearby to help if things go seriously awry. https://youtu.be/IMYWFWqUZ9c https://youtu.be/sebg51EheUo https://youtu.be/ODC_iOXTuIQ
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 05-02-2020 at 03:07 PM. |
05-02-2020, 10:53 PM | #3 |
Removed my '72 C20 spindle, upper and lower control arms as a unit. Here's some pics and the vid I watched on YouTube. On the drivers side I even left the caliper and rotor attached. Good Luck.
https://www.youtube.com/watch?v=5krg5346SK8 |
05-03-2020, 08:38 PM | #4 | |
05-08-2020, 11:38 AM | #5 |
Dropping them from the brackets on the cross member probably is the fastest way. You still will need to watch that spring when they come loose. Assuming you are just going to junk what you take off, I wouldnt hassle with trying to separate the pieces.
Yes it will work for the other truck. Make sure you disconnect brake hose before hand Also be aware of your feet, that assembly is way heavier than you might think = broken foot. When it drops be ready, if its junk dont try to stop it, let it fall. I would recommend unbolting the bottom control arm first bc it bolts up vertically to the cross member, remove spring and continue. Put the jack under the brake drum assy so when you unbolt the top control arm it wont drop and mess your threads up. Also you want to make sure those threads on the top stay in good shape so spray a bunch of PB Blaster every few hours for a couple days before you plan on taking action. You will have two nuts on the top control arm, four on the bottom (two u bolts), per side. Take note of your spacers on the top control arms, when you go to replace put them back so the alignment guy is halfway close.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations Last edited by May70; 05-08-2020 at 11:45 AM. |
