Old 08-15-2020, 04:20 PM   #1
ltdmstr
ltdmstr's Avatar
Looking for -6AN adapter for PS pump
So I'm doing a bunch of work on my '68 C10 and one is adding power steering in place of the stock manual setup. It's a 250 straight 6 and I have the pump and mounts that I purchase from the classifieds. I'm also adding disc/drum power brakes with a hydroboost assembly in place of the manual drum/drum setup. With this setup, the power steering lines run from the pump to the hydroboost then to the steering box then back to the pump. I figured I'd make my own lines using Earl's power steering hose and connectors which are very nice. The problem I've run into is, the stock power steering pump is 5/8-18 male flare fitting, and all the Earl's stuff is -6 AN. I've spent hours searching for an adapter to go from 5/8-18 male to -6 AN female, but have yet to find anything. I've also spent an hour on the phone with techs at Summit, and they couldn't come up with anything either. I tried calling Earl's several times and despite long waits (45+ minutes), nobody ever answers the phone there. I even tried calling the corporate number multiple times, and no luck. So I'm just wondering if maybe someone has a suggestion on how to solve this.
ltdmstr is offline   Reply With Quote
Old 08-15-2020, 05:20 PM   #2
Richard
Re: Looking for -6AN adapter for PS pump
Since you are making your own hoses could you just make that hose with -6 at one end and 5/8-18 at the other?
Richard
Old 08-15-2020, 05:21 PM   #3
ltdmstr
ltdmstr's Avatar
Nope. They only make -6 AN hose ends. So I need some kind of adapter between the two pieces.
Old 08-15-2020, 05:25 PM   #4
Richard
Do you need a male or female thread for the hose end at PS pump?
Richard
Old 08-15-2020, 05:27 PM   #5
Richard
https://www.summitracing.com/search/...inverted-flare
Richard
Old 08-15-2020, 05:31 PM   #6
MidnightChevy
A picture would help but I think an AN894 or NAS1564 would work. Try giving Genuine Aircraft Hardware a call at 805-239-3169. They should be able to get you what you need.
MidnightChevy is offline   Reply With Quote
Old 08-15-2020, 05:35 PM   #7
ltdmstr
ltdmstr's Avatar
So here are photos of the pump, and the Earls hose end.
Old 08-15-2020, 05:38 PM   #8
ltdmstr
ltdmstr's Avatar
Basically, what I need is this, but with female threads on the 5/8 end.
Old 08-15-2020, 05:46 PM   #9
ltdmstr
ltdmstr's Avatar
The AN894 looks correct, but the sizes don't match. I can try them on Monday, but don't see a match on their site.
Old 08-15-2020, 05:49 PM   #10
MidnightChevy
I think that you need the NAS1564 then. Let me find a picture of one.
Old 08-15-2020, 05:52 PM   #11
MidnightChevy
https://www.gen-aircraft-hardware.co...f/ftgadapt.pdf
The file was too big to upload. Looks like you might have found it on your own, though. It says they have more sizes available so it's worth a call. Hope it helps.
Old 08-15-2020, 05:55 PM   #12
Richard
Maybe change the flow control valve to get what you need? A quick search turned up this https://www.jegs.com/i/JEGS+Performa...yABEgK51_D_BwE
Richard
Old 08-15-2020, 06:02 PM   #13
ltdmstr
ltdmstr's Avatar
Got it. If I'm reading it correctly, it looks like the NAS 1564 is straight thread female to AN male, which is what I need. The chart shows 5/8 female to -10 AN male. I'll call them Monday and see if they have 5/8 female to -6 AN male. Thanks.
Old 08-15-2020, 06:11 PM   #14
ltdmstr
ltdmstr's Avatar
That would be great if I can find one with internals that matches the stock part. I'll do some checking and see what I find.
Old 08-15-2020, 06:19 PM   #15
Richard
Still poking around for my stuff saw this https://www.jegs.com/i/JEGS/555/100708/10002/-1
Richard
Old 08-15-2020, 06:25 PM   #16
ltdmstr
ltdmstr's Avatar
I thought that would do it, but internally it's cut for a double flared hard line, not for the male end of the pump fitting. Same for the versions from Fragola and Russell.
Old 08-15-2020, 06:40 PM   #17
Richard
If you decide to go the flow restrictor route give Turn One a call, am sure they can get you what you need. Maybe even get an adapter. I had a custom PS pump built by them. Very good to work with. https://turnonesteering.com/
Richard
Old 08-15-2020, 09:28 PM   #18
ltdmstr
ltdmstr's Avatar
I'm not sure how well a flow restrictor will play with the hydroost. But I may give them a call. If something is out there that will work, maybe they'll know.
Old 08-16-2020, 02:25 AM   #19
Richard
Probably should have use the same term I did in a previous post "flow control valve" or regulator. Anyway they know their stuff regarding steering components. Built me a type 2 pump for my ls swap that flows over 5 gpm at 1500+ psi. Hopefully will handle the ram assist steering and ported hydro-boost setup I am installing on my truck.
Richard
Old 08-17-2020, 02:52 PM   #20
ltdmstr
ltdmstr's Avatar
Still no luck. Tried calling all the suggested sources and many others. Probably spent another 3-4 hours on the phone this morning. Can't believe this isn't a common item. Probably going to have to try to return the hose and fittings and get some custom lines made.
Old 08-17-2020, 05:53 PM   #21
siggyfreud
siggyfreud's Avatar
Not likely going to be common because many aftermarket PS pumps have a female 5/8 port rather than a 5/8 male fitting. Probably fewer people retaining the stock/fitting pump but not the stock-style hoses. So I'm not sure the market justifies the existence, which is unfortunate in your case.
siggyfreud is offline   Reply With Quote
Old 08-17-2020, 07:11 PM   #22
roboticjunky
Remove the fitting that is on your current pump. Then put these fitting on. https://www.summitracing.com/parts/clp-cpfcv-k
roboticjunky is offline   Reply With Quote
Old 08-18-2020, 01:31 AM   #23
Richard
If I could not find the correct regulator I would probably just get a new or reman PS pump from a newer gen truck. Same style pump was used through the 80's and it will have the female thread output. Adapters to the -6 seem readily available for those. Maybe post in the later model parts section for the regulator.
Richard
Old 08-18-2020, 12:08 PM   #24
ltdmstr
ltdmstr's Avatar
I suppose not too many people are using the old pump with hydroboost, etc. I'm just surprised that with just fittings available for pretty much any conceivable combination, nobody makes one for this. So, the latest is that I ordered a part from inline tube that looks like it will work with the old pump and has female threaded output. If that works, I can get a male/male adapter that will work, and problem solved. But I'd say chances are 50-50 it will work. Problem is I have to wait a week for it to arrive via USPS bc inline tube doesn't offer any kind of expedited shipping. At this point, I'll just be happy if it works. If not, it's custom hoses or a new pump with female output.
Old 08-18-2020, 12:13 PM   #25
A1971Blazer
A1971Blazer's Avatar
lot of fittings here
https://leepowersteering.com/collect...ering-fittings
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
