09-14-2020, 08:20 AM | #1 |
radio connections
just bought a oem radio for my 78. Is there a bracket or some sort of support for the back of the radio? or does the two front stems hold it in by itself?
Have 10 wires coming off two pigtail and one red hard wired wire, I know the gray and black wire (one pigtail) are for the radio light. I assume the hard wired red wire is power, are the other 8 for speakers? Two for each speaker. Can someone confirm this Thanks |
09-14-2020, 08:41 AM | #2 |
Re: radio connections
Yes there should a bracket.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
09-21-2020, 09:59 AM | #3 |
If you have to make one because it will brake you plastic of your Face Bezel in time,(the factory radios are heavy) make noise some times because shakes a little some times.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
