Old 07-29-2022, 10:38 AM   #1
67-C10
67-C10's Avatar
ECE Drop Brake Hose Question
So I bought an Early Classic Enterprises 3.5/5 drop for my 1967 c10 some 15 years ago when I got the thing then life happened and I’m finally getting going on it again. With the switch to front discs from the kit and ECE now closed what brake hoses should I be buying. I have no brake lines installed and have to buy a complete new kit anyway. I assume I should get the lines for a 72 with factory discs but is there better hoses I should be getting due to the drop?
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now.....
Needed: paint and lots of it. and i'm sure lots more misc. parts.
Project 67 short step Build Thread
01 Sierra Crew 6.0
2015 Ford F150 Work gave me truck i really wouldn't buy a ford.
67-C10 is offline   Reply With Quote
Old 07-29-2022, 11:13 AM   #2
67C10Step
67C10Step's Avatar
Re: ECE Drop Brake Hose Question
Your question begs another question. Have you maintained the lines to the rear of the crossmember or moved to the front similar to the 71/72 setup?
I used a complete kit from Inline Tube that maintained the lines in the factory locations. The front flex lines were for a 1969 Buick GS. I think the Autozone part number is 88466.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 07-29-2022, 11:37 AM   #3
Grumpy old man
Grumpy old man's Avatar
This thread might help .
https://67-72chevytrucks.com/vboard/...d.php?t=818077
Old 07-29-2022, 08:54 PM   #4
67-C10
67-C10's Avatar
I have no brakelines on the chassis whatsoever and figured I'd get a set of 71/72 to put in place seeing they were factory disc front. This helps. Thanks.
01 Sierra Crew 6.0
Old 07-29-2022, 10:34 PM   #5
Mike C
Mike C's Avatar
Then just buy 71-72 disc lines.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
