#126 |
Re: '84 K10 Engine Build Questions
Took a trip to the junk yard today looking for a flywheel. There were only three manual trans Chevy trucks in the whole yard! Two trucks had V6 in them and of those two, one had the trans removed already. I took the pressure plate off and it didn't look like the flywheel I needed so I moved on to the V8 truck. I had to pull the whole engine to get the flywheel off. Luckily everything to the engine was disconnected already. Only bolts I removed were the bell housing bolts and the 2 motor mounts. Much to my surprise, once the engine came out I found a brand new flywheel, friction plate and pressure plate! I mean, this thing didn't have but a couple hundred miles on it. I couldn't believe it! So i took the whole thing. The flywheel surface has 2 spot the size of a quarter that shows any wear. This thing isn't even broken in yet!
#127 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yep, you got lucky there. That doesn't happen to me very often.
#128 |
Anyone have any tutorials or tips for cleaning up a carb? This will be another first for me. If I take it apart to clean are there gaskets I have to replace or can they be reused?
#129 |
Registered Truck Offender
Where the he11 did you find that carb??? at the bottom of a lake? Myself I wouldn't use a Edelbrock carb again on any build,, but especially not that one!!! Appears in the pic to have significant corrosion damage to the metal base sealing surface,, and just makes you wonder ...
I say take the top off, and if the insides are not PRISTINE,, toss it back in the lake! (BTW, the Edelbrock rebuild kit is like $75)
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#130 |
It's either rebuild this or rebuild the qudrajet that I took off the old motor which needs serious help. I've seen it dumping fuel out the ends of the shaft seals and probably needs other stuff because when the truck sat for a while the bowls seems to drain and I would have to crank it a lot...
If I crack it open and its bad I'll probably consider buying a new carb but I'm willing to give this a try. Most of what you see is grunge from sitting, I don't think it was actually use much at all according to the guy I got it from. I bought that and a Torquer II from him and I've already got my money back in just selling the intake... Last edited by Marshy; 11-22-2015 at 11:31 AM. |
#131 | |
This is a couple of reputable Q-Jet builders from a Buick site I attend on occasion; http://www.v8buick.com/forumdisplay....erformance-LLC http://www.quadrajetpower.com/home.html Both are great Q-Jet rebuilders that can even refinish your carb to make it look brand new if you would want that service as well. There is also Cliff Ruggles that rebuilds Q-Jets for your combo; http://www.cliffshighperformance.com/ The Q-Jet carb was made for a lot of different vehicles and were application specific so don't waste your $$ on a Summit rebuilt one size fits all Q-Jet. One of the sites above will get that Q-Jet to be a plug and play for your application with just having to adjust the idle speed and idle screws, done. GL |
#132 |
Awesome, thanks!
I was wondering if anyone has some advice on how to go about setting the lash when you don't have a timing mark on the timing cover? I have a dial indicator I could put on the rocker but not sure that help me any. I have to order a bolt on timing marker as my cover doesn't have one but I don't want to wait for one. What do you suggest? I'd like to set the lash while I have the intake off but don't want to let this hold me up. Should the oil system be primed when setting lash? I set them nearly to zero lash for the time being. |
#133 |
So I'm setting the valve lash. Got some advice to set number 1 intake as it's exhaust just opens and repeat for all intake then Webster is set when intake closes...
Anyways, I ran into an issue I believe but not sure. A couple of the lifters look collapse. Is it OK to set the lash with these collapsed? Could I take the lifter apart and put some oil in it so it's not collapsed? I just did it to one and it's solid again... ![]() |
#134 |
OK, so my machinist said 1/8-1/4 turn from zero lash is where I should set them. I guess I get to do it all over again. :-/
#135 |
60-66 Nut
What did you set the valve lash to?
Are those lifters used or new? The spring inside should keep the cup at the top against the keeper unless it is collapsed or broken.
#136 |
I put them all at 1/4 turn in from zero. The lifters are used and came with the engine. I went through them all and cleaned them thoroughly. A couple of the same type bleed down. There are two different kinds installed. I didn't take pictures.
I put the oil pan on after resetting the lash and masked the timing cover, heads and lifter galley and gave everything a shot of paint. The block and heads were thin in areas sobi wanted it all to get some more. Tomorrow will be install the intake, dip stick, paint the valve covers and install then paint the plug wire brackets and maybe clen up that Edelbrock cab. I cracked it open and it just has some sediment, nothing serious. The outside the way worse than internal. Pics later. Last edited by Marshy; 11-24-2015 at 01:23 AM. |
#137 |
#138 |
60-66 Nut
The 1/4 turn past zero lash should be fine. However I would be concerned with any lifters that look like the one in your pic above. Hopefully someone else will come along and give their opinion but I would consider replacing those.
It looks like that carb should clean up well with a good soaking in carb cleaner. I rebuilt an Edelbrock once using a kit for an AFB since it was less money. It seems like it didn't come with an accelerator pump though.
#139 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() Last edited by Ironangel; 11-24-2015 at 05:49 AM. |
#140 | |
#141 | |
Anyways, the reason I'm coming back to this is because I'm cleaning up my old water pump and noticed that the pump has the bypass hole where it mates to the block but, again no hole in the block at the pump mating point. I tried to get them both in the same pic. ] ![]() So I'm going to put it together the way it is... What I'm having a little trouble with now is figuring out what goes to ask these threaded holes in the manifold near the thermostat. Anyone help me out? It's a little different than my old manifold... There's one to the right of the USA tag, then I've right in the g face under the same tag then one to the left of the thermostat hole. ![]() Last edited by Marshy; 11-28-2015 at 01:07 PM. |
#142 |
Electric fuel pump and relay switch reference.
http://67-72chevytrucks.com/vboard/s...ump+conversion http://67-72chevytrucks.com/vboard/s...ump+conversion Last edited by Marshy; 11-28-2015 at 02:51 PM. |
#143 |
So I forgot to put a dab of RTV in between the two keys for the harmonic balancer. Does it have to come off or can I put some on the end like this?
#144 |
60-66 Nut
If your block does not have the corresponding casting and hole for the bypass hole in the water pump, I believe you will need to plug that hole in the water pump. Otherwise you will leak coolant from that hole.
On the intake manifold, the hole on the passenger side of the thermostat is for your heater hose connection. The one on the other side is often used for a temp gauge sender or simply plugged. It is better to put the temp gauge sender in the head if your sender will fit that hole. The hole in the front is there for use as a thermostat bypass if needed. I have seen electric fan temp sender's in that location, a bypass hose or simply plugged.
#145 | |
Well im about to slide this engine in and started cleaning up the firewall and bell housing. Since I'm putting in a new clutch in I thought it would be a good idea to replace the throwout bearing too. I cant get the bearing off the input shaft. Anyone have a tip? The lever arm won't move far enough to allow the bearing to slide off the shaft. I must be missing something, please help. ![]() Why did GM use so much sealant on the firewall? I want to clean it up and see the paint, this looks like ****, any suggestions? |
#146 |
I got the bearing off the input shaft. It was late when I was trying last night and never thought to slide the fork back away from the shaft. It slid back then I would pivot it far enough to get it disengaged from the bearing.
#147 |
60-66 Nut
No the gasket and sealant will not be good enough. The hole needs to be tapped and a pipe plug installed.
That undercoating on the firewall will likely need to be scraped off. Often times a little heat helps.
#148 |
It's coming off with a puddy knife and a light hand. The Gunk degreaser is softening it up nicely and a nylon brush and rag is getting the leftover without damaging the paint real bad. I'm going to leave some at the seam but most of this is going to be removed. It's already looking better and ibhavent done much yet.
![]() I'm going to scrub a little more on it then I have to move on. I have some black paint to touch up the inner fenders after I knock the surface rust off then this motor is going in. ![]() |
#149 |
Before:
![]() Now: ![]() I'll finished up the cleaning tonight and shoot some low gloss blank on the inner fenders and call it good. I want to clean the grime off near the heater core and over by the brake MC and giver everything a nice wipe down. A final wash with some simple green will take the oily gunk cleaner off. Last edited by Marshy; 12-01-2015 at 10:18 AM. |
#150 |
Senior Car Nut
![]() Join Date: Jan 2008
Marshy, I haven't been following along with this particular thread but I see you put a old style timing cover on. wish now I had done that. you should be able to get a bolt-on timing tab for that cover.
Larry |
