05-05-2009, 09:33 AM | #1 |
Restoring a tailgate band
What methods have you guys used to restore a tailgate band? I just bought one that is in extremely nice condition but has 1 small scratch that you can feel with your fingernail. The part looks to be anodized from the factory (like the old Brite-Dip that GM used to use on their metal grilles). I would like to duplicate the polished edges and the lightly brushed-finished center.
05-05-2009, 01:13 PM | #2 |
Re: Restoring a tailgate band
i have the same question. mine is the narrow "Cheyenne" style. i am guessing some sort of light buff will shine it right up, but am afarid to try
05-05-2009, 11:21 PM | #3 |
Look at 78 Chevyrado's threads . He restored his truck and I think a tailgate band was one of the pieces he did . His work is nice on the truck and will give you some direction .
Frank
Born and proudly residing in a Red State ! |
05-06-2009, 12:23 PM | #4 |
Thanks, I'll look up his threads.
05-20-2009, 05:03 PM | #5 |
hey guys, i was interested in this too. I tried to find 78 Chevyrado's in the members list but couldn't. am i missing something?
05-21-2009, 04:35 PM | #6 |
I have been looking myself the closest I can find is this
http://67-72chevytrucks.com/vboard/s...=309004&page=2 check out post 38. It is not a step by step but may give you an idea |
05-22-2009, 02:06 AM | #7 |
I'll just tell ya...lol I don't know where the thread is either, but it must be there somewhere...lol'
First thing, If your band isn't too bad you can probably just wipe it down lightly with some WD-40. I used to do that on my 87, and it made it look like new until the oil went away again. On to what I did to this band: I got a used band off of ebay. It was faded like they usually are, so I tried a new to me way to fix it that has worked so far with no problems. First thing to do is get any and all old paint off of it, like the outer trim like and the chevrolet letters. Then I used some of that etching aluminum wheel cleaner on it. I let it soak in good for 5 minutes or so and then rinsed. The etching cleaner got all the stains out so the aluminum was all the same color with no splotches. At this point the band will be white, but don't panic....yet lol. Then take a scotchbrite pad to scuff the surface LIGHTLY. you don't want scratches on the smooth part of the aluminum, and on the brushed part make sure to only rub WITH the grain, not across it. Also be sure to get down in the paint line groove and the in the chevrolet letters good. It won't matter if it gets scratched where black or yellow paint is to go, just don't scratch it where the aluminum will show. Once you have it clean and oil free and scuffed up, spray it with a clearcoat. Lay the panel face down, and put on a light first coat just to make sure the panel is as clean as you think it is. Then put on a second coat just enough to get good coverage. At this point the band will kind of look milky, again don't panic... I left mine out in the sun all day and within a couple of hours the clearcoat had lost all the milkyness and cleared up and I ended up with this Now it's time to paint the letters and outer stripe on it. The reason you have to clearcoat it first before doing the letters, is if, like me you have to mask off the letters to paint them, you need the clearcoat for the tape to stick to. I put tape on the raw aluminum after the etching cleaner, and when I pulled the tape off, every single bit of the adhesive came off the tape and stuck to the band. Big mess... Make sure to use a tape with an easy relase adhesive. remember you didnt scuff up the surface much and used no primer, so be careful with the clearcoat when sticking things to it. Let it dry in the sun a day or two before using tape on it. Then mask off and paint your letters and stripe and then let them dry a day, then put another layer of clear over the whole thing. I put mine on kind of heavy, where it wouldn't have as much texture to it when it dried. Here's my finished band, with black stripe and Gold Chevrolet letters. The emblem on the right side isn't stock, but was part of a broken fender emblem, and it cover the small dent in the band quite nicely and looks stock to people who don't know any better. I later added the silverado part of the fender emblem too, but it's not stock. All they do is hide a dent. Last edited by 78 Chevyrado; 05-22-2009 at 02:09 AM. |
03-25-2010, 06:29 PM | #8 | |
thats a cool idea |
03-25-2010, 07:53 PM | #9 |
awesome thread!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
03-25-2010, 08:17 PM | #10 |
Are you using rattle can clear or do you use the real stuff? I have a band off my GMC for sale, If it doesn't sale I might do this method you described, but I don't have the funds for real clear, just rattle can.
In God We trust!!! Last edited by Panelman55; 03-25-2010 at 08:17 PM. |
03-25-2010, 08:39 PM | #11 |
GREAT THREAD!!! I'm gonna try that on a couple of my bands!!!
1994 C1500 rclb 1988 C1500 rclb 1969 ES5500 B E A S T 1983 C10 'farm truck' 1976 K20 Suburban 1984 K10 Suburban 1981 Jeep CJ5/350 Vortec 1941 Dodge WC18 Ambulance 2000 GMC Bus (parts warehouse) |
02-23-2011, 12:58 PM | #12 |
I used the rattle can spray clear from advance auto parts.
FYI: after more than 2 years of use, it still looks freshly painted. |
11-26-2012, 06:37 PM | #13 |
which scotch brite pad did you use?
11-26-2012, 09:47 PM | #14 |
What if you've got a few dents?
11-26-2012, 09:49 PM | #15 |
Mine was anodized and so far I've only gotten half of it off. Pita new old stock one too
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-28-2014, 01:12 PM | #16 |
Subscribed for reference. Great job!
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
01-14-2015, 09:44 PM | #17 |
I had a couple of dents in mine. Sanded it down using sanding sponges and taped of the edge and sprayed it black. Then pulled the tape off and used I believe a 1000 grit sanding sponge and polished the edges and cleared it all. After about a year and a half it is still holding up. Attached Images |
01-14-2015, 09:48 PM | #18 |
01-15-2015, 01:58 AM | #19 | |
04-26-2015, 12:57 PM | #20 |
What did you use to remove the paint?
