08-05-2010, 08:59 AM | #1 |
DRL override
Am I remembering this correctly, or did I dream this:
I recall that you can turn the Daytime Running Lights off by pressing the "dome off" button three times within three seconds (or something like that). Anybody else ever heard of that or something simliar? Thanks, K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-05-2010, 11:29 AM | #2 |
laying low
Re: DRL override
That's the first I've heard of that procedure. I thought there was a DRL relay under the dash I removed on my 97.
What vehicle are you working on Keith?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
08-05-2010, 11:32 AM | #3 |
Old Skool Club
Re: DRL override
Keith, the only way I know of (and did) to turn them off was to pull the 20-amp fuse (#15) out of the instrument panel box (driver's door). I did it to allow my son, who was the principal driver of my truck, to be able to actually turn his headlights off as he passed through the gates of his duty station in CA.
When you pull the cover to access those fuses, it is labeled DRL-FOG. So, if you have fog lamps (OEM) they probably won't work, either. The DRL relay is under the hood in the "convenience" panel.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 08-05-2010 at 06:08 PM. |
08-05-2010, 11:55 AM | #4 |
Re: DRL override
My 99 S10 would do that but not my 98 C1500. I believe there is a fuse for the DRL in the fuse box in the side of the dash.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
08-05-2010, 02:11 PM | #5 |
Frequent Flyer
Re: DRL override
Pull the DRL-FOG fuse like said above.
I've done it pretty much first thing on all the trucks I've bought that were equipped with them. |
08-05-2010, 02:13 PM | #6 |
Re: DRL override
Hmmm...it's a '97 Suburban.
I wonder if I'm thinking of a later model year? At any rate, one technique would be to just barely apply the park brake, which turns the DRL off but then you have the brake/indicator light on in the dash. I noticed it did not say anything about the dome override in the Owner's Manual. No fog lamps, so I'll see about pulling the recommended fuse. Thanks guys - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-05-2010 at 02:14 PM. |
08-05-2010, 03:13 PM | #7 | |||
Re: DRL override
08-05-2010, 03:27 PM | #8 | |
Re: DRL override
Ok - thanks - (on both counts) K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-05-2010 at 03:27 PM. |
08-05-2010, 03:31 PM | #9 |
Old Skool Club
Re: DRL override
The green DRL light will still come on, although the lights don't.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-05-2010, 03:35 PM | #10 | ||
Re: DRL override
ECHO...echo... |
08-05-2010, 06:07 PM | #11 |
Old Skool Club
Re: DRL override
Again, 1badgmc.....my bad. Thanx for bringing that to my attention. I look at these posts and read stuff and reply w/o comprehending it very well, at times.
So, there should be no question about that green indicator light.....
08-05-2010, 06:14 PM | #12 |
Re: DRL override
I owned a 2000 Silverado and you could hit the dome light something like 3 times and it would turn the running lights off.
So that's all you gotta do it pull a fuse on my 99 Tahoe huh? |
08-05-2010, 06:17 PM | #13 | ||
Re: DRL override
08-05-2010, 06:21 PM | #14 |
Re: DRL override
Well...I just recently put some Sylvania Silverstars in my 99, and it'll be my luck that having the DRL on all the time will end up wearing them out that much faster. Supposedly the life span of the Silverstars isn't that great. Last edited by Ghastlyone; 08-05-2010 at 06:22 PM. |
08-05-2010, 06:39 PM | #15 | ||
Re: DRL override
08-05-2010, 06:50 PM | #16 |
Re: DRL override
I have the Ultras in mine. The light they put out is amazing.
08-05-2010, 07:03 PM | #17 |
Re: DRL override
I thought that when I had them in my Impala. Since that time I've been used to driving with the factory HIDs in my CTS and the HIDs I've put in everything else. When I ran the Ultras for a bit in my Suburban before going to HIDs in it...man were those Ultras yellow!
08-05-2010, 07:49 PM | #18 | |
Re: DRL override
I'm not real knowledgeable on HIDs yet, what are you running in yours? Are they just bulbs? Or is it a full kit with fuses, etc? |
08-05-2010, 09:58 PM | #19 |
78K & 79C Jimmys
Re: DRL override
rather than put the ebrake on ,i put a switch in to the ebrake contact,shorts to ground and the lights go out,up here they have to be on after a certain year.and the cluster brake light remindes me to turn it back on before someone else drives it.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
08-05-2010, 10:11 PM | #20 |
Old Skool Club
Re: DRL override
motornut....you guys north of the border have had DRL's since about '68, or so.....if my memory serves me correctly.
08-05-2010, 10:21 PM | #21 | ||
Re: DRL override
In my Suburban I have 4500K HIDs from DDM Tuning with a hi-4 kit and a relay harness. Both kits are of pretty much equal quality, but I prefer the color of the 4500Ks in my Suburban. Quote:
If you want, I can give you a good crash course in HID 101. It might be good to start another thread. |
08-06-2010, 10:24 AM | #22 |
78K & 79C Jimmys
Re: DRL override
drl have been required on new cars since bout 90 up here
08-06-2010, 11:07 AM | #23 |
Re: DRL override
So I pulled the #15 fuse yesterday afternoon. I'm not sure why I never did this before now.
08-06-2010, 11:17 AM | #24 |
Re: DRL override
08-06-2010, 02:24 PM | #25 |
Re: DRL override
Does anyone know if it's the same for my 06 Trailblazer SS? I can just turn the headlight switch off, and they go off until the next time I start the truck. However like you guys I hate seeing them on. I just wasn't sure if pulling the same fuse would affect the auto on light setup that the newer vehicles have.
I wish they were the stand alone lights like my 03 Sierra, or the signal lights at least. |
