Old 01-29-2012, 02:02 PM   #1
Old_1965_Gmc
305 v6 power steering question
I was tryn to figure out if the 305 v6 ever had any power steering do they make any aftermarket power steering whole assmeblys for these engine or would I just have look out for a good assembly if i ever find one
Thanks,marco
Old_1965_Gmc is offline   Reply With Quote
Old 01-29-2012, 02:54 PM   #2
creep
Registered Loser
creep's Avatar
Re: 305 v6 power steering question
Yes, they did. I bought a used stock PS pump and bracket off ebay a couple of years ago. To my knowledge nobody makes any aftermarket parts for these motors except tranny adapter plates and those are really expensive.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 01-29-2012, 07:18 PM   #3
Old_1965_Gmc
Willi be looking at spendin high dollers just for the whole assembly even though its a used item I'm really thinking of adding this power steerin i f ever get my hands on one sence the steering is nerve racking espacilly when I have the 4 speed manuel tranny
Old 01-29-2012, 07:27 PM   #4
duallyjams
duallyjams's Avatar
Do a search on here there a lot of good threads upgrading to a power steering box. You can get the double grove pulleys off of a big truck. You can use the power steering brackets off of a 67-69 pick up also. they would be easier to find. A T rockdriller made his own brackets for his power steering.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-29-2012, 07:43 PM   #5
Old_1965_Gmc
Can someone write awhole list of parts needed to properly install the the power steering even pics would be a real help well not just me but others that would like to know the same question
Old 01-29-2012, 08:42 PM   #6
jbgroby
jbgroby's Avatar
Here is my album on the add on of EOM equipment
http://rides.webshots.com/album/571837084bSxNPf
jbgroby is offline   Reply With Quote
Old 01-29-2012, 10:04 PM   #7
Old_1965_Gmc
Really nice albume with all the info thanks jbgroby so the only thing I was wondering now was the bracket dose it have to be from 305 v6 engine.
Old 01-29-2012, 10:30 PM   #8
jbgroby
jbgroby's Avatar
Yes it does. I'm seriously thinking that IF we pitch together, one of us could take one of the OEM brackets and have it remade at a good shop. YOU out there Capt. Fab?
Old 02-02-2012, 02:10 AM   #9
Captainfab
60-66 Nut
If I had the original brackets to go off of, no problem fabricating new brackets. I would have to see if I could find a V6 around here to check fitment on though.
Old 02-02-2012, 08:44 AM   #10
duallyjams
duallyjams's Avatar
I have both sets of V6 power steering brackets (no they are not for sale ) 60-66 and the later version 67-69 for pickups as big truck brackets are different.
The later version will work on the early trucks.
Capt if you want I could mount it up on my V6 take some pics and send you the brackets so you can copy them.
James
IG duallyjams
Old 02-02-2012, 09:07 AM   #11
jbgroby
jbgroby's Avatar
Cap. I have no problem pulling my bracket off, do you have an idea on how long you would take? Be glad to ship it to you for the benifit of others. Please PM me. jbgroby@charter.net I'll send you back some pictures so you can take a look see before you commit.
Old 02-03-2012, 01:39 AM   #12
Captainfab
60-66 Nut
Is there an advantage to either the early set or the later set of brackets. I wonder which ones would be easier to reproduce. Maybe if I could see some pics of both sets.
I'll send you an email Jake.
Old 02-03-2012, 09:16 AM   #13
duallyjams
duallyjams's Avatar
I'll get pics up Saturday.
James
IG duallyjams
Old 01-29-2012, 10:33 PM   #14
Old_1965_Gmc
That would really be nice to see one fab for the 305 v6 engine
Old 01-30-2012, 12:58 AM   #15
Old_1965_Gmc
Hey captainfab ever though of fabbing a power steering bracket for the 305 v6 engines
Old 01-30-2012, 11:00 PM   #16
Old_1965_Gmc
Jbgroby the pic #2 on ur albume do I have to have one like that from the same year make and model or can I use a diffrent later model cyclinder ram
Old 01-30-2012, 11:32 PM   #17
jbgroby
jbgroby's Avatar
I'm not sure if you can use a different ram set up. I would suspect that you could but you will need to check with one of the guru's.
Old 01-30-2012, 11:42 PM   #18
Old_1965_Gmc
Well I recently upgrade my 8 lug to a later c10 disk brake that's y I asked if I can just use a later model type
Old 01-31-2012, 09:06 AM   #19
duallyjams
duallyjams's Avatar
Check out rock tonka pic it has a factory power steering pump
http://67-72chevytrucks.com/vboard/s...d.php?t=505836
James
IG duallyjams
Old 02-01-2012, 09:59 PM   #20
Old_1965_Gmc
That would be suthing nice to have and origanl even better but the I know when it come n lookin for sunthin like that its like findn a needle in the hey sack just lookin for simple build if I can ever find the nessary part and stuff
Old 02-02-2012, 11:16 PM   #21
Old_1965_Gmc
Yea if u commit in makeing the bracket let us know when its done ill have payment ready for u captainfab
Old 02-05-2012, 01:05 PM   #22
HEI451
I used a wide belt pulley Cadillac pump for my conversion, and made brackets from scratch, came out much like dually's.
I'll have to revise them to raise the pump, as I have just found a two piston air pump I want to engine drive with an electric pulley clutch. The pump looks a lot like the ones I have seen on these years trucks. I will use it for a small air tank under the bed, as my truck will end up as a workable 1 ton service dually flatbed, with hoist and other helpers in place.
HEI451 is offline   Reply With Quote
Old 02-05-2012, 03:19 PM   #23
Old_1965_Gmc
Yea like duallyjams said maken a bracket that fits today later pump would be the best option
Old 02-10-2012, 01:24 PM   #24
Old_1965_Gmc
Any new infor about the brackets?
Old 02-11-2012, 02:22 AM   #25
Captainfab
60-66 Nut
No, not yet. Trying to find a V6 locally that I can use for mockup. I may have to make them without one.........I did find a complete power steering setup for a V6 though.
http://spokane.craigslist.org/pts/2772866638.html
