Mystery harness...to me anyway
what is this wire harness for? 1972 C10, 2 wheel, 350ci, standard trans. It is not the engine or front light harness, it comes out of the fire wall to the right and slightly above the engine and front harness junction to fuse box. My 1970 C10 does not have this harness..
Thanx in advance...
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
US Army Veteran
![]() Join Date: Nov 2008
Re: Mystery harness...to me anyway
Just look at my '72 and have the same harness coming out of the same location. It runs behind the inside of the driver fender, comes out at the front of the inner fender.
It looks like it would go to the alternator and/or external regulator. The thick red wire probably goes to the alternator and the green wire would most likely go to the temp sending unit.
1972 C10 Highlander - The making of a daily driver |
#3 | |
That is the tcs ( transmission controlled spark ) wiring. If you look there is prob. A relay on pass side and also a round vac. Control located on the intake.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#5 | |
Thanks...since this build now has a 383, 700r4 etc can this harness be eliminated..? Relay is gone..no vac control on the new Weiand intake...
The flip side of the picture.
http://67-72chevytrucks.com/vboard/s...d.php?t=627794
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#7 | |
Thank you...this is a big help.
Yes you can make it all go away.
