12-01-2009, 08:58 PM | #1 |
cigarette lighter power and high fan setting
Ever since I bought my truck my high setting on my fan and AC did not work as well as my cigarette lighter. I was under my dash to fix my neutral safety switch and found the cigarette lighter wire not plugged into the fuse box. plugged it in and now my high setting on my fan and heater control works.
Im guessing these are wired somehow to the same fuse. Does anyone know off hand? maybe it might help others trouble shoot if they happen to have the same problem. |
12-01-2009, 09:21 PM | #2 |
Active Member
Re: cigarette lighter power and high fan setting
I would say someone wired it up that way to make a cig lighter work
If you look at the control panel I would think you will find a connector tapped into the power wire
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
12-12-2009, 12:24 AM | #3 |
I have almost the exact same problem with my truck. The high setting on my fan didn't work and neither did the cigarette lighter. They were spliced together and wired into the CIG port. The connector was melted, and the fan was only getting about 8.7V. I replaced the wire and hooked it up to the relay. I now 12V for the fan, but still can't get high to work, so I ordered a replacement relay. We'll see if that works. Where is the fan power supposed to be hooked up to the fuse box, and how did you get yours working?
1972 Chevy C-10 ~ 188,000 miles give or take |
12-12-2009, 08:26 PM | #4 |
Chemist under the hood...
With the other fan settings, the voltage changes to run the blower slower. Have you tried a voltmeter to see what you get when the switch is on high? There is a blower motor resistor that changes the voltage but I believe that the high speed is straight 12 V to the blower.
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
12-12-2009, 08:39 PM | #5 | |
How is it spliced is it a cheapo butt connector or soldered here's a diagram of the ac circuit it shows the hot side of the high speed relay plugged into the cig port.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
