Truck and auto performance nut
Converting '68 GMC to '67-'68 Chevy grill
I just purchased a '67-'68 Chevy grill for my '68 GMC. It comes with the front parking/turn signals and the trim. I am guessing all I will need is the headlight trim bezels to finish the appearance side but am wondering about the "behind the scenes" work in this conversion process. What will I need to do, to adapt this grill and 2 headlight system... to my 4 headlight system GMC?
I have a '72 C10 to scavenge the lighting harness off of if needed and noticed my GMC's wiring includes a relay or something on the radiator support. Can I use my '68 GMC radiator support? I am guessing I just remove the high beams and leave those mounting buckets hidden behind the grill, and then change the wiring? How about the center support brace that the hood latch and everything mounts to? And since its still a GMC (just with a Chevy grill) what year GMC emblem might work good in the two holes left in the grill from the bowtie emblem? One off a '99-'06 GMC? my new grill (its just the wrong color): Thanks for any and all assistance!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 09-17-2007 at 03:24 PM. Reason: add info |
Re: Converting '68 GMC to '67-'68 Chevy grill
hmmmm......
![]() nobody? ![]() I mean I know ![]() ![]() ![]() I guess I'm in the gray area between Chevy and GMC.... where the GMC guys won't help because they feel I'm abandoning them.... and the Chevy guys think I'm a poser...... ![]()
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Next project: 1970 K10
Radiator support, headlight buckets, and bumper? 'Bout all I can think of.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
A guy with a truck
The reason you're not getting much response is that you're in the wrong forum.
You will need to remove the headlight buckets from your core support and drill for the adjusters or use a 67-68 Chevy support. Wiring you should be able to integrate and use a 3-prong style plug to the single headlights. Emblem I don't know...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Wrong forum? Its a project...thats part of a build?
Or do I need to start a "build" thread only in this forum? I guess maybe it looks like a grill swap only on the surface but I am in the middle of placing my '68 GMC's body on my '72 C10's chassis, for the benefits of a V8, turbo350, front discs, bigger rear drum brakes, and rear coil suspension. Then I'll start the tear down of the '68 frame, get it blasted and powdercoated, and build it up with mostly new parts...while I'm still able to use the truck (the '68 body on the '72 chassis). Someday when the chassis is ready, '68 body and '68 frame will reunite.
68 GMC I performed this swap and changed everything from the firewall forward and it worked great. The core support and hood are different I believe.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
Questionable
I think this forum is intended for build threads only. If this is your build thread, great, but if the only reason for creating it is to ask questions about how to do something in your truck, my personal belief is that it belongs in the main forum. This cuts down on the clutter and keeps project-only threads in here for archive/reference by others.
This is just my 2¢. I wish you luck on the buildup, but I'll add some more opinion: I think it's blasphemous to convert a GMC into a Chevy. ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
I would agree if I was "converting" a GMC to a Chevy. I just happen to like the painted Chevy grill better then the '67-'72 GMC options, so I'm swapping out the "grill". The tailgate will still say GMC, and most likely there will be a front GMC emblem of some sort applied eventually to the nose. For many people that do not know the '67-'72 trucks as well as folks here do...when they look at the truck (and the emblems).....it'll just look like another old "GMC" to them.
![]() And a grill... hardly a truck makes.... I mean, I guess I could swap the title info from my '72 C10 to my '68 GMC... and then call the '68 GMC a '72 C10 with a '67-'68 front clip (and swap the tailgate for my bowtie one). It would still be the same truck, but then the '67-'68 grill would be kosher. ![]()
