Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-16-2008, 10:57 PM   #1
pharmd
pharmd's Avatar
Pro-touring 65' C-10
If you were going to build a true pro-touring 65' chevy step side, one that was built to really perform on a road course, YET was able to be driven cross country like the power tour...how would you build it? Suspension, drivetrain, motor, brakes, cooling...how would you do it?
pharmd is offline   Reply With Quote
Old 10-16-2008, 11:02 PM   #2
Super73
Super73's Avatar
Re: Pro-touring 65' C-10
I would:
3-link the rear suspension
Buy C5 or C6 front control arms, spindles, front spring
Find a LS1/2/3 with a 98-02 6 speed from a Camaro
That would be a pretty good start.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 10-17-2008, 03:50 AM   #3
ripdog28
ripdog28's Avatar
3 link rear,
Boxed frame,
Mustang II front end,
LS3 W/440hp with a charger/turbo 500+hp (about $8500) and full wire/computer set up from jegs or summit (LS7 500hp/24mpg if had $12grand) OOH yes 6 speed as well.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 10-17-2008, 07:26 AM   #4
djracer
djracer's Avatar
17 or 18 inch wheels, Baer brakes, Big Nasty sway bars front and rear, Watts link out back instaed of panhard, Trailing arm rear with urethane upgrades. Coilovers on all 4 corners. Lowered of course. Normaly Aspirated nasty Ls motor with a built 4l80. Rack and pinion Steering. Recaro seats. Kickin Stereo. Relocate battery and tank to rear. I'm sure I could come up with more! This would make an awesome ride.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-17-2008, 12:30 PM   #5
ripdog28
ripdog28's Avatar
im in the middle of installing my watts link at the moment with some boxed trailing arms, will look sick with the polished aluminum when all done. will tell everyone to get down on all 4 to look at the rear end when done haha.
69 c-10 BBC
Old 10-18-2008, 01:41 PM   #6
leftcoast66
leftcoast66's Avatar
+1 I'd o almost identical except for the auto. I'd most definitely go 6 speed for being able to control precisely when you shift comin into corners and such. And being able to heel toe so you wouldn't break the back tires loose down shifting on the brakes.
Originally Posted by pharmd View Post
I got the motor situation covered, but I am rather new to road race suspension...so give me some pro/cons for the rear suspension (watts link / 3 link vs upgraded stock suspension) and front suspension C5 vs mustang II vs upgraded stock...
I am doing coilovers on my 07' TBSS, already has sway bars, Belltech springs, DJM upper A arms, but the ride quality needs help, hence the coilovers.
Watts link rather than the panhard is because the panhard follows an arc since it attaches at one side, so therefore it pushes and pulls the axle to the side during its range of motion. Whereas a watts link doesn't. Honestly I don't know enough about 3 link vs 4 link to give it proper justice explaining, so I'll defer to someone who knows all the details so I don't misinform. For front suspension, I think its more whatever you feel more comfortable with. I think on this board there are a lot more people running c5 so it would be easier since there is the help, but with mustang 2 its been used forever. Upgraded stock would kinda be ugly, cuz the steering isn't as sharp, and a lot more turn to turn. In the bmw world, 2.5-3 turn to turn which is from being locked in one direction to being locked in the other direction is optimal, so I personally would follow that idea, which with stock it has more slop than a rack and pinion, and also you wouldn't be able to get the turn to turn down from stock, because corner carving will be a really lot of work with a lot of turn to turn cuz you'll have to move your arms so much to get it pointed the right direction.
leftcoast66 is offline   Reply With Quote
Old 10-17-2008, 12:56 PM   #7
djracer
djracer's Avatar
cool post pics
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-17-2008, 10:28 PM   #8
shortbed70
shortbed70's Avatar
I would be more traditional and keep the truck arms but go 2x4 frame tubular uppers and trailing arms\watts link and bags all around 18" magnesium wheels big sway bars,brakes,oh yea if moneys no object get my 454 motown (aluminum)and get the best fuel injection kit I can find and then turbo it.....6 speed all the way. If I couldn't fund that motor I would build a 377 with the lightest rotating assembly I can find add some compression,injection and run N\A with a monster roller cam.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 10-17-2008, 10:58 PM   #9
pharmd
pharmd's Avatar
Old 10-18-2008, 02:35 PM   #10
Super73
Super73's Avatar
A 3-link avoids all bind through bumps. A properly set up 4-link can too, but it's not that easy to do. The factory truck arm suspension, all though not bad, isn't adjustable and can cuase binding issues too.
Here is what a 3-link looks like. This is my 73 road race car I am building. http://ls1tech.com/forums/showthread.php?t=644613
I went with a PH bar due to packaging. Will there be rearend shift through a bump? A little. How much is based on how long the PH bar is.
There are also pics of the front suspension. Had I to do over again, I most likely would have went with C5 or C6 parts. Why? Easily replaceable, light and proven. Mustang 2 stuff is not a bad option, but I think you could get more tire under it with C5 or C6 parts. Either one though has a large aftermarket for brakes ect.. The nice thing about the C5/6 stuff is packaging for your springs. They use a leaf in the front and it sits low and out of the way.
Old 10-18-2008, 07:06 PM   #11
71shortwide
71shortwide's Avatar
I was looking at the 3 link setup but i didnt like how it mounted to the cover and ran across this.
Any one used or seen one like this?
Justin
71shortwide is offline   Reply With Quote
Old 10-18-2008, 10:10 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by 71shortwide View Post
....Any one used or seen one like this?Justin
That's a Watts Link kit from KP Components.-LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-18-2008, 11:33 PM   #13
djracer
djracer's Avatar
I installed one of those watts links with a 6 link air bag setup on my buddies 03 silverado recently. Its very sweet.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-20-2008, 08:57 AM   #14
pharmd
pharmd's Avatar
Lots of good information guys...so for my 65' application, to run a 3 link, would I have to custom fab some stuff, or are their companies that make a conversion kit...What kits/systems out there would you all recommend that will require the least amount of custom fabrication, yet allow very good performance?
Old 10-20-2008, 09:44 AM   #15
Mykk
Ya know, I've always wanted to build an old pickup with the engine / drivetrain in the bed. To me a short box 65 would prove to be a better candidate for such a project compared to the 67+
It looses it's function as a pickup, but most rods do. And it wouldn't be very weather safe unless it could fit under a tonneau cover. But it would be unique, you could build a nice flashy engine with some cool stacks type induction and really turn heads when you pull the front wheels off the ground with light throttle.
Mykk is offline   Reply With Quote
Old 10-18-2008, 09:26 PM   #16
Super73
Super73's Avatar
Thats not a 3-link.. Thats a version of a Watts link.
This is a 3 link:
See how there are (2) lower control arms and (1) upper control arm. That's a 3-link. A 4-link would have 2 uppers and 2 lowers.
A Watts link or Pan Hard Bar keeps the rear end centered under the the car from left to right where the 4-link, 3-link, ladder bar, torque arm ect keeps the rear from moving forward or backwards.
Old 10-18-2008, 09:43 PM   #17
71shortwide
Ya thats my mistake sorry
Old 10-20-2008, 11:45 AM   #18
Super73
Super73's Avatar
Lateral dynamics makes one for a F-bodies. I personally feel their upper link isn't super stout, but I'm sure it could be made to work in a truck with minimal adjustment. You could add to the upper front mounting point by running 2 trianglulated bars up the the fram.
http://www.lateral-dynamics.com/
http://www.lateral-dynamics.com/products/
Old 10-20-2008, 10:44 PM   #19
pharmd
pharmd's Avatar
You think that this could be done with minimal intrusion into the bed area?
You mentioned the upper link not being that strong...
Which part were you talking about, would this be a real problem if it wasn't tracked heavily, and could I modify it to be stronger?
Old 10-21-2008, 12:10 AM   #20
leftcoast66
Looks to me like the top of the axle is the mount that isn't super strong. Yeah you could definitely modify it to make it stronger.
Old 10-20-2008, 04:42 PM   #21
leftcoast66
Could piece together something from summit. Tragically I think your in uncharted territory as far as most of the big companies are concerned and at least some fab will be needed to make it work.
Old 10-21-2008, 12:40 AM   #22
Super73
Super73's Avatar
I don't have first hand experiance with this set up. I didn't say it was weak, I said that I felt it "isn't super stout"
If you look at the front mounting point, it is made from what looks like 1x3 square tube and could shear. Now, in the car, they are welding it in to the floor pan which is adding a lot of "sheer" strength.
But still not quite the same as having it backed by some serious tubing.
If I were putting it in a truck, I would not use their front support unless it was severly reinforced.
Old 10-21-2008, 12:49 AM   #23
Super73
Super73's Avatar
Here are a few more. BTW, My rear upper mount does wrap the back of the rear housing.
Old 10-21-2008, 06:25 AM   #24
djracer
djracer's Avatar
Would that not be real similar to a trailing arm setup with an improved third link to replace the panhard bar?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-21-2008, 10:34 PM   #25
pharmd
pharmd's Avatar
Has anyone at all, done a similar set up that I might be able to check out, or reference. Who or what shop(s) would you guys recommend talking to to maybe get a little assistance on a project like this. Remember, I am a pharmacy owner, and I am kinda co-in-charge of 5 stores, so time is in short supply around here.
