Future TOTM Winner
The Great Critter Revival ‘09
Well, I figure it is time for me to put this in some sort of build thread, even though at the moment it is made up more of destruction than building.
A little history…I had been looking for a 1st gen Blazer off and on starting around 2001. I got serious a couple years ago and picked this one up in August of 2006. I knew it had some issues but I also knew it had a lot of the options I wanted. I.E. tilt, A/C, 350/TH350, etc. After I bought it I realized it was a Highlander package as well. For the last couple of years I have been gathering parts, casually fixing things, and getting it road worthy. Tuned up the engine, rebuilt the tranny, rebuilt the front axle/spring bushings, new rear suspension. Blah, Blah, Blah. This winter it finally became fully street legal…just in time for me to get serious about restoring it. I have most of the big parts gathered up like a full set of virtually spotless OEM sheet metal to bolt on (except for a driver door that I am currently looking for), along with a new rear axle and some newer style GM seats from a 2001 truck. The rest of the parts like, grill parts, pretty much all of the interior pieces, and all the seals/gaskets and so on will be purchased as I go. The first pic is where she was sitting back in 2006. The others were taken after I had done some work.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 02-25-2009 at 12:36 AM. |
Future TOTM Winner
Re: The Great Critter Revival ‘09
As far as my goals for this thing, I plan on taking the resto-mod approach. I want the body to look basically stock as far as trim, bumpers, and a solid color paint scheme (still haven’t figured out which color that will be), the interior will be stockish with modern updates here and there. Under the hood things such as wiring and plumbing will be cleaned up and improved as needed and the original 350 will be rebuilt and mildly upgraded. I would like for it to eventually be nice enough for me to take to local car shows and club gatherings, along with weekend drives to the river, beach, etc. I don’t plan to run it up and down the rocks or anything but at the same time I’m going to drive it where I want and ENJOY it.
I also think I need to add that I have owned and worked on a number of old Chevy trucks, but this is my first attempt at a “frame off” rebuild, so I’m sure it will be slow and painful for everyone. ![]()
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Future TOTM Winner
I started pulling the front clip off a few weeks ago and then the doors. This week I got going on the rockers. Here are a few pics of you typical rust. I had a fairly decent idea of how bad it was being that I could see most of it through the holes. Time to order some patch panels…site venders here I come. I plan to totally fix the drivers side before I move to the passenger. Plus I got a couple little spots to fix on the firewall, but they are on flat surfaces and should be fairly easy to patch.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 02-25-2009 at 04:50 PM. |
Future TOTM Winner
Finally got the drivers rocker off. YEAH! As I figured, I will need inner and outer rockers, the outer floor strip, kick panel, front cab corner, and lower front bedside area.
Future TOTM Winner
...and a couple more for the heck of it.
Future TOTM Winner
here they are
#7 | |
For your inner rocker replacement, look into the part Tri-Pro sells for trucks, you get alot more to work with than the blazer version. The full length truck part includes the lower 'A' pillar holes and a fair amount of floor area too, it'll give you more option's to work with. Pic of the part I'm talking about: ![]() Here's a decent thread to look over, it addresses where your heading... ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=249323 Enjoy... |
![]() Join Date: Jan 2007
Watching this one...I will have a comparable fix on a 72 4x4 Blazer when it shows up in a few weeks from Columbus, Ohio after a trade for my 72 C/20...
Good Luck with your build - as overwhelming as it will be - the end result will justify the stress of doing it... |
#9 | |
I'm a poor spectator
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Gotta love Texas. In Nebraska it is extremely difficult to find something in that good of shape. Everything has been rotting forever here. Good find, I really like the wheels.
What's it called when you use your own name in the title for your build thread?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
#12 | |
Technically speaking, Critter is the name of his blazer, he's a wierdo.
If you don't mind me going off topic and asking, what is the highlander option?
![]() Join Date: Feb 2000
Will be a fun project to watch - sounds like you have a good plan. The color looks alot like the color on my K5.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#15 |
Cool rig!
I love those wheels....anyone know where you could get them in 8 on 6.5?
71 ![]() |
#16 |
![]() Join Date: Jan 2009
I too will be watching closely as I will be doing the same to mine this spring and summer. I will have to replace bottom boxes also. nice project truck keep at it you'll get it done. at least that is what i will be telling myself during mine to try to keep a little sanity.
Are you supporting the pillars with anything while you do the work or is the boxes doing their job still?
BE NICE IT PAYS IN THE END. |
#17 | |||||
Future TOTM Winner
![]() Quote:
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 02-17-2010 at 01:54 PM. |
#18 |
This should be an interesting build to watch. I cant wait to see more.
#19 | |
At a minimum, do something to maintain the door opening. ![]() Your going to be getting into the front pillar and once you break it loose, you'll be amazed at how much the firewall is going to move. Fair warning though, build the brace so it's 'convenient' to work around. ![]() |
#20 |
Active Member
Keep at it, you can take care of that. I admire the heck out of you for bringing back your K5. I've always liked the dark green Blazers.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum 2004 FORD FX4 SuperCrew 2005 CTS-V 12 sec family car ![]() 2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it! |
#21 |
Shame it's that bad in the cowl area, but it's to be expected as all the crap falls into it. I would take more metal out back to the seams, then you can really get a handle on it. If you leave the forward edge, where the curve starts, you should be able to fix it with a flat sheet of metal. When mine go bad, I want to put in a piece of stainless and screw it in so I can check it from time to time. Also this will allow you to put a sealer between the seam and metal
Whats the inside area look like(kick panel)
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-02-2009 at 10:50 AM. |
#22 | |
Future TOTM Winner
http://67-72chevytrucks.com/vboard/s...ad.php?t=72472 It gave me the false sense of confidence I need to start cutting ![]() Oh, and my kick panel has some rot along the bottom 1 inch where it meets the floor board, no better or worse than most of the others you see around here.
#23 |
Have fun this weekend and take lots of pics for us to look at, I'm a junkie for people's progress
#24 |
Future TOTM Winner
Day 12…
ordered drivers side patch panels from Tri-Pro yesterday… found more rust around the firewall today…I’m scared… starting to freak out…
#25 |
Dude, your knee deep in it now. A little more work and the Critter will be on the road in no time. Gimme a shout if you need a hand. Way to go so far though. Later.
