03-07-2009, 02:02 PM | #1 |
Prostreet / Dragrace 1972 blazer
I have been building this blazer since last june and am trying to finish it by june of 2009. It started as a rolling 4x4 chassis and a 598 bbc that I built.I found an extra blazer and stole the frame,which I stripped of the running gear and all items.I then had it sand blasted along with all front 2wd suspension. I have the truck as a complete roller currentley. I installed new drop spindle and springs,aftermarket rallies, art morrison ladder bar coil over setup on a 9inch with strange pro iron case and 35 spline axles.The gears are 3.89 with detroit locker.I have willwood dynalites in the rear and Mickey T drag radials.I also have a 10 point cage to install,I need to set the tub on and take it to the shop 4 cage install. My blazer has a 1967 front clip,with
UP22 four inch cowl fiberglass hood.I shaved the wiper cowl,firewall,dash,and smoothed off the top. I will post more pics as I can. |
03-07-2009, 02:07 PM | #2 |
Re: Prostreet / Dragrace 1972 blazer
great looking start ..should be alot of fun
03-07-2009, 02:15 PM | #3 |
SKINNY TIRES RULE!
That engine is a monster! Can't wait to see it finished.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
03-08-2009, 06:30 AM | #4 |
The LuvShack Garage
Subscribed
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
03-08-2009, 09:42 AM | #5 |
Very interesting!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
03-08-2009, 10:48 AM | #6 |
more pics for you
03-08-2009, 11:47 AM | #7 |
Nice Engine! Sure to be a nice Blazer when completed
03-08-2009, 04:51 PM | #8 |
I love the glovebox door instrument panel. Cant wait to see more pics.
03-08-2009, 08:26 PM | #9 |
I wont be home for 2 more weeks,then I can shoot more body pics.The yellow blazer is the body I found here in Alaska for 1000 and it was 98.5 % rust free.The gold one I bought for the frame and paid 300.These trucks are very common here but rusted out underneath,we all deal with this though.LOL
The 1967 shortbed is friends and is bagged and awaiting a 6.0L install |
03-08-2009, 11:03 PM | #10 |
Great start! Can't wait to see her completed.
03-09-2009, 10:30 AM | #11 |
Here are a few more pics I had.
08-26-2010, 01:29 AM | #12 |
Nice build. You using a glove box for your gauge's correct? those racing seat bolt to the stock location? And has anyone seen a thread on a longbed prostreet or am I about to be the first?
03-10-2009, 10:03 AM | #13 |
Ready to go fast!!
im diggin your style! lol i love pro street blazers
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
03-11-2009, 02:47 AM | #14 |
VA72C10
Wow, I'll be watching this one.
Looking for a 67-72 swb or blazer project in or around VA. |
03-11-2009, 05:18 PM | #15 |
Thats looking really good
70 SWB STEPSIDE 70 BLAZER 09 challenger |
03-11-2009, 08:08 PM | #16 |
2WD Jimmy
What are you doing for a cage. NHRA is picky with full frame cars... be sure and read the rule book. I didnt think the 'Full' cage would look good with the top off, so I went with a roll bar with door/shoulder kick-outs that connect to the front of the frame just behind the front control arms. This limits me to 11 second ETs if the tech guys see it as a ,convertible... I beleive it would be good for 10 second ETs if they see it with the top on and list it as a 'hardtop'.
Havnt been to tech with mine yet, maybe this summer... just food for thought . Mine is similar to yours. Tom from Paso Robles, Ca. PS... I am Sooo jealous of where you live. |
03-11-2009, 08:26 PM | #17 |
Looks like alot of fun.
I was wondering about your back brake setup. I'm running a 9" in my mud blazer also and want to put the dynalite on it too. I've seen the weld on brackets in speedway and plan on using the hats with matching wilwood rotors. My question is what brackets, hats, and rotors did you use. Mainly if you have a part # for the hats if they are back spaced enough for the weld on brackets or if there are some better brackets. Thanks Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
03-12-2009, 12:10 PM | #18 |
Dynalite complete kit for ford new big bearing. Its a 2.5 offset. This kit was sweet and costs about 650 the brackets bolt on the rotors are 2 piece also.
03-13-2009, 11:40 AM | #19 | |
Thanks. I'll check it out.
03-12-2009, 12:31 PM | #20 |
PROJECT 7DEUCE
Very nice build love the pro street action..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-12-2009, 06:54 PM | #21 |
niiice!
03-17-2009, 04:05 AM | #22 |
Well ithink are 2 builds are alittle diffrent as mine will be quite tame for its power level and should idle smooth at 900 or so. I made mine able to drive and is built for future spraying which could be fun. I ordered 10 pistons from JE when I built this and it has there blown/nitrous tool steele piston pins.
I really think it can get into the 9's without juice!! So did the converter tech at ATI. Good luck with the project. Got any pics ? |
06-23-2009, 02:44 PM | #23 |
So here are a few pics of the body now.The dash,cage,and firewall along with the door jams have all been prayed. I need to hand and align the doors and front clip, then wetsand and the color can be layed out on the rest of the body. On the bright side the engine and trans are back in for good now! I am very happy with the smoothed dash and firewall.It is worth all the metal work we preformed. I will try keep the pictures current. I am planning to go 4 a ride in it in september. Keeping my fingers crossed. Thanks for checking out the progress.
06-23-2009, 03:05 PM | #24 |
couple more pics
06-24-2009, 04:17 AM | #25 |
So here are some pics of the engine installed with carb and exhaust.I will try and get the doors hung and adjusted tommorow.
