Old 05-03-2009, 10:12 AM   #1
capev86
need template for cab lights for new burb
hello:
i just joined this club and i'm about to pass papers on a 72 burb 3/4 ton 2wd. my dad had a 72 1/2 ton 2wd back in the 80's....a custom deluxe fully loaded with cab lights. well...we found the truck in a local junkyard in '95 a couple years after my dad had sold it. the interior and all the usable pieces had been stripped (the floors and rockers were gone from rust) but i saved the chrome teardrop roof lamps that were one of my favorite features.
i am hoping to mount them on my new truck after i take delivery in a couple days but i need the template or whatever that the dealer used to mount the lights. i don't want to guess, i want to get the positions exactly. anyone know where i can get something like this?
the truck has the original 307 with the 3 on the tree and only 77k on the clock so it will run good for now (i have a 406sbc and 700-r4 saved for the future that we ran in my dad's 84 sub 2wd...his second burban). it has a class 2 frame mounted hitch with a bar and i plan to replace that with a class IV hitch for heavy trailering. the other upgrades that i plan for the near future are 1-1/4" front and 1-1/8" rear sway bar to make it more stable. later on i plan to replace the sporty mirrors with the stainless flip out towing mirrors from my dad's 84 (saved before junking it) burb and the trailer brake controller and wiring (also from the '84) that i swapped into his current 87 2wd burb and will be donated to my truck eventually.
other than that i will fix up the couple tiny rust blemishes and just enjoy driving my classic suburban. my dad is looking into downsizing when the inspection runs out on his 87 (ex-texas truck that is rusty after 10 years up here in maine) and i wanted to carry on the mantle. i was heartbroken when he sold his 72 and vowed that someday i would have one for myself. i will do my best to keep it in good shape but it will certainly see its share of hard work carrying people, cargo and towing trailers (we still have our 71 holiday 23 footer that we originally hauled with my dad's 72). having the cab lamps installed will bring back a taste of my childhood, especially with the trailer hitched up.
i am 29 years old now and 26 of those years my dad has had suburbans. that and dodge aries wagons.....we had an 81 (last new car my parents bought) and 86 k wagon and the 72 and 84 burb from 1990-91. 2 car and 2 truck wagons. i still have the 86 aries wagon (it was my first car) and it is slowly being restored and stealth modified (shelby daytona suspension and spirit r/t big 4 wheel disc brakes as well as a plethora of aftermarket goodies to tighten things up). you could say these old haulers are in my blood! actually, i just took the 97 sable wagon from parents which they replaced with an 01 taurus wagon. the sable just became my current daily driver. 197,00 miles and still going strong. i'm crazy, but i love my wagons!!
capev86 is offline   Reply With Quote
Old 05-03-2009, 09:50 PM   #2
capev86
Re: need template for cab lights for new burb
more info on the lights....they are those 8 inch long yankee brand chrome teardrop lights that were very prevalent back in the day.
Old 10-11-2009, 11:49 AM   #3
capev86
i know i started this thread awhile ago......hoping someone has or can make a template for me. thanks!
Old 10-11-2009, 10:03 PM   #4
budder71
I just bought a set of NOS cab lights on ebay this week and they should be delivered next week. These were still in the box all still sealed up with mounting instructions so as soon as i get them in I will update you about the template !!!
budder71 is offline   Reply With Quote
Old 10-12-2009, 02:49 PM   #5
capev86
You Are Awesome!!
Old 10-14-2009, 09:01 PM   #6
budder71
got them in today.. u got a fax number ?
Old 10-15-2009, 10:27 PM   #7
budder71
send me a pm with a faxd number and I will fax you the instructions and details on where to put the cab lights...
Old 10-16-2009, 09:30 PM   #8
capev86
i will get back to you with a fax number once i have one. too bad you couldn't scan it in and then make it available to the whole group!
thank you!
Old 10-20-2009, 12:38 AM   #9
tripp
i need the same info. pm'd you.
68 SWB Stepside
72 Cheyenne 20
72 SWB Fleetside
72 Suburban
72 2wd Blazer
tripp is offline   Reply With Quote
Old 10-20-2009, 06:44 PM   #10
capev86
hello budder71....
i got the fax and i will try and get the instructions posted one of these days. my dad has a printer with a scanner built in. the plans show what looks like a late 50's gm pickup cab, but you can tell they are the 8" yankee lamps. the middle 3 are spaced 6" apart from each other but the big variation is one setup puts the outer 2 at 25" from centerline with the back end tipped in 2-3/4 inches and the other setup calls for 35 inches from centerline and only a 2-9/16's tip in. i am guessing since the 67-72 has a wider cab like the modern trucks it will use the wider spread plan. i also don't recall my dad's truck having the side lamps really cocked, only slightly. i will know better after i climb up on the truck, take some measurements and look at multiple angles with the lamps mocked up. if only i'd made a template back in 1995 when we found my dad's 72 burb in the junkyard 5 minutes from his house. it must have been fate because he sold it to a guy a 1/2 hour away over in new hampshire and there were/ still are several larger junkyards over that way.
Old 10-22-2009, 10:47 PM   #11
budder71
that set of instructions was for 62-67 Chevy Trucks up to 2 Tons..... maybe it will help
Old 10-24-2009, 07:50 PM   #12
capev86
i might still have to get some measurements from a 67-72 truck with the yankee lights to make sure i have the right measurements. others please chime in.
Old 10-25-2009, 08:21 AM   #13
rockc
I am needing a template and a set of instructions also.
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 10-25-2009, 08:35 PM   #14
budder71
there is a 72 Suburban on ebay currently that has the cab lights and they are mounted exactly as the templet/set of instructions I faxed you...
Old 10-28-2009, 05:07 PM   #15
capev86
nice truck....wish i could put mine in a dealer showroom for the winter!
Old 10-28-2009, 05:15 PM   #16
capev86
i can't post the images....nothing over 199kb and these are like a couple meg's....any smaller and the pictures are useless......
Old 10-28-2009, 07:50 PM   #17
rockc
capev6 what ya gonna do with them after ya use them? I sure need some or copies.
Old 11-07-2009, 04:54 PM   #18
capev86
i will likely file them away like i do with any other pertinent paperwork. i could email you the files.
