1987 (Vss)Vehicle Speed Sensor location
I am getting code 24-vehicle speed (vss) sensor circuit fault.
I am not sure where the sensor is located. If anybody could advise me of where it is located I would appricate it.Also if anybody has ever had the same code give me some feed back on what it exactley was. Appriciate it ![]() |
BAD BOW-Silverado XST
Re: 1987 (Vss)Vehicle Speed Sensor location
LOL, the sensor is located on the trasmission tail housing. Is your speedo working correctly?
24 VSS Set when in motion only - disregard if set in park http://www.cfm-tech.com/gm_tbi_trouble_codes.htm |
![]() Join Date: May 2011
I just checked on my '87 and I am getting the same code. Speedo works when the truck is cold but after a few miles it stops working. No speed sensor on the transmission tailshaft on my 700r4. Just and adapter with the cable coming out of it that goes to the speedo. Is there a speed sensor behind the speedo?
Watch out for your cornhole !
![]() Join Date: Jun 2003
Little green box behind the instrument cluster.
78K & 79C Jimmys
1989 burb
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
What was the outcome of your speed sensor issue?
I have a 89 and i feel mine is affecting my timing but i never get any codes. If i put my truck in neutral while drifting even at 5mph my idle increases to 1500 rpm. |
#8 | |
Posted via Mobile Device |
