06-24-2003, 12:42 AM | #1 |
starter ?
the starter sticks on when I turn the key, any ideas why? we just took the nose cone off of a auto starter and put it on a manuel starter, which did work at the time.the only thing I noticed was diff. was on the silinoid(5 yrs of spelling didn't help) where the little bolt goes thru the copper bushing and attaches to the stater was alot shorter on the man. vs the auto. in a nut shell why won't the stater disengage?
06-24-2003, 12:46 AM | #2 |
Registered Abuser
I would guess that the sylinoid is staying energized or that the spring in the sylinoid is busted
06-24-2003, 12:49 AM | #3 |
spring is new along with the syliniod.
06-24-2003, 01:03 AM | #4 |
Designated A-hole!
Does the starter gear have the same size/number of teeth? Flywheels (man) and flexplates (auto) may have different number/size of teeth, causing something to stick. I am just guessing but maybe something to check.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-24-2003, 01:30 AM | #5 |
switch
Is your switch returning from the start position to the run position ? Somebody had to ask.
06-24-2003, 02:49 AM | #6 |
Its Magically Delicious
i had this problem ..still kinda do ...it got alot better after i threw a few shims on .... strange though it still does it once in awhile
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
06-24-2003, 12:49 PM | #7 |
Yeah, once the sillynoid engages the gear, the disengage is spring activated. If the gear is binding too tightly to the flywheel this might prevent a disengage.
I can't see how this could be a sillynoid problem. Ah, a great excuse to use the word "Sillynoid" again. Brian |
06-24-2003, 01:43 PM | #8 |
Mine liked to do that when it gets hot!
So I riped it out and bought a small high torque starter And will never go back. These things rock and they sound mint too!!! |
06-24-2003, 01:57 PM | #9 |
Gotta luv a clean shave
Does it keep cranking or does it just not disengage from the flex plate?
Welding while you wait...you can help if you like and it...might even save you a little as long as you don't mess things up! We make house calls too...just like the old days! |
06-24-2003, 02:34 PM | #10 |
I like the flywheel idea, and the switch is ok,and it doesn't disengage from the flywheel. has NE1 ever changed the gear on a starter B4? how about the spacer/bearing at the end of the shaft, the thing the gear hits after its engaged?
06-24-2003, 05:34 PM | #11 |
Spank 'em if you got 'em!
Good luck resolving this. I am interested to know the end result.
I always buy everything I can w/ lifetime warranty. So far I have gone through...5 starters...for various reasons. Is it feasable to just replace the cylinoid? New starter is $39.
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
