Old 11-18-2014, 08:56 PM   #1
Kobush
67 c30 cummins swap
Hey guys I'm new around here. Just getting started on the motor swap in my 67. Starting to test for the fittment now. Should be a fun build.
Kobush is offline   Reply With Quote
Old 11-18-2014, 08:58 PM   #2
Kobush
Re: 67 c30 cummins swap
Old 11-18-2014, 08:59 PM   #3
Kobush
Old 11-18-2014, 09:26 PM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice! I like those wheels and the fact it is a dually all together. What trans are you going with?
Ryan
1969 Chevy milk truck
Old 11-18-2014, 09:33 PM   #5
Kobush
Thanks. Putting in the nv4500 trans that came out of the donor truck.
Old 11-18-2014, 09:36 PM   #6
Dieselwrencher
Nice! That will make for a sweet truck. Welcome to the forum, too by the way. Has anything been done to the engine yet?
Ryan
Old 11-18-2014, 09:49 PM   #7
Kobush
The engine is stock with 230k miles on it. Trying to decide how I want to build it now. Not sure if I'm gonna go single or dual disk clutch then go from there.
Old 11-18-2014, 10:20 PM   #8
Kobush
Old 11-19-2014, 02:34 PM   #9
shopteacher
What style of motor mounts are you using?
Keep up the good work.
We need more 2WD Cummins swaps here !
My Cab and Chassis is sitting under about 3 inches of snow right now !
shopteacher is offline   Reply With Quote
Old 11-18-2014, 10:12 PM   #10
Kobush
Does anyone make a steering bar like the one in front of the crossmember that's bent down. Would like to trim the crossmember to allow the motor to sit lower.
Old 11-19-2014, 03:12 PM   #11
burnin oil
South Bend Clutch makes some really nice single disc clutches that hold alot of power. DD suck if you dont need them. Alot of pressure for the pedal, sluggish shifts and tend to be in or out (not alot of slip). Don't get me wrong because I love my street dual disc in the tow rig and it has never slipped but a good single is alot nicer to drive unless you need alot of holding power. Another thing is all all the dual discs I know of take a larger input gear in the nv4500 and it is costly.
burnin oil is offline   Reply With Quote
Old 11-19-2014, 04:08 PM   #12
shopteacher
The clutch system that I order from Six States is a Kevlar on the pressure plate side and an organic on the flywheel side! They can handle an easy 500hp and do not chatter like a stock clutch! Plus they run about $500 !
Old 11-19-2014, 10:03 PM   #13
Dieselwrencher
On your steering, I'm not sure. I don't think so but I could be wrong.
Organic dual disc is the way to go for a tow rig with decent power. If you use a diaphram pressure plate with a 3250 plate load, the pedal will be nice and soft and it'll hold the power up to 550hp I believe. You can have a dual disc made with small input as well. If you need a price on one let me know. We've had a few built mainly from Valair. The Kevlar clutches are okay. But once you slip that Kevlar, it is not forgiving and usually is junk after that. Had a couple of customers find this out the hard way.
Ryan
Old 11-19-2014, 10:15 PM   #14
Kobush
Did some more fitting last night. Looks like the steering will be ok it's just a very tight fit.
I'm not planning to do much towing with the truck. I might pull car trailer with it a few times a year but mainly just going to be driving it around. I'd like to see it around 500hp when put together, with that in mind single or dual disk?
Old 11-20-2014, 12:01 AM   #15
Dieselwrencher
For what a good single costs to hold that power, I'd just jump up to a street dual disc that is organic. Then you don't have to worry when you start to increase the power. I've fried my share of single discs and learned the hard way.
Ryan
Old 11-20-2014, 12:41 PM   #16
burnin oil
My SBC single held way more power than it was rated at and never slipped. It was abused hard with alot more than 500HP. After breakin grabbyness was almost stock in feeling. As dieselwrencher was saying the organic street duals are the best compromise. Mine is a 3250 which is identical to the 3600 except doesn't have the SFI rating. Avoid anything kevlar and go organic or organic with metal in it. Same principal as upgraded brake pads. In my diesel trucks I do spend money on good clutches but my gassers just get cheap 12" upgrades. You are paying for a quality clutch with alot of clamping force. Avoid centerforce clutches. They use centrifical force (unless they came out with a new model) to get more pressure which is fine in a high winding mill but Cummins are brutal right of idle. As far as single vs dual I will stand behind the single unless you drive like a total idiot. You can still come off the clutch hard then dump the throttle and it will live a long life. Something has to give when you dump the clutch like a sled puller and it is going to be the weakest link. You just hope that its the cheapest part. My 5500 puts enough power to the ground that I shattered a driveshaft flange! No I do not abuse the truck as it is a tow vehicle but the clutch never missed a beat. Torque will always find the weakest link.
Old 01-03-2015, 12:49 PM   #17
Kobush
Thanks for the input guys. I went with the dual disk organic clutch. Here is a pic of the upgraded shaft next to the factory
Old 01-03-2015, 01:24 PM   #18
Kobush
Got the frame painted
Old 01-03-2015, 07:36 PM   #19
Kobush
Craigslist find of the week. Found this clutch pedal setup. A little bead blasting and good as new.
Old 01-03-2015, 08:09 PM   #20
HemiChallenger71
HemiChallenger71's Avatar
Looking good.
What rear gears do you have?
Is the donor a 215hp engine?
Planning on any other nv4500 upgrades while its out?
HemiChallenger71 is offline   Reply With Quote
Old 01-04-2015, 12:22 PM   #21
Kobush
Thank you. The rear gears are 3.55 I believe. It's a 215 hp motor. The only upgrade I had planned for the trans was the input shaft. But is there anything else I should consider doing while it's out?
Old 01-04-2015, 05:49 PM   #22
HemiChallenger71
YES! Something about a 5th gear nut, especially the early nv4500s, which you have. You'll need to do some research, I cant remember the specifics.
The 3.55 should be nice for you, especially in a 2wd. Watch that 2-3 shift.
Old 01-04-2015, 07:43 PM   #23
Kobush
I'll check it out thanks.
Old 01-04-2015, 08:29 PM   #24
marvgarr68
marvgarr68's Avatar
The cummins will hammer the 5th gear nut off. The fix is a castle nut.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 01-04-2015, 08:32 PM   #25
Kobush
Anyone have any experience with these cheap eBay injectors?
