12-10-2014, 04:35 PM | #1 |
Rusty 68 K20 Burb
Picked up this 68 last Friday. She is pretty rusty, but I saved her from the scrappers or just rotting away on a farm.
I picked her up cheap, she was actually a gift from my 4x4 buddies because they knew I always wanted a slant nose 3 door. The plan is to use her as a family wagon/wheeler. I want to swap the frame with my 78K20 Burb with a 350/465/205 and 60/14 Combo with 4.56's and a detroit in the rear. I want to exo cage her and protect what body is left. Pic's coming. |
12-10-2014, 04:44 PM | #2 |
Re: Rusty 68 K20 Burb
12-10-2014, 04:55 PM | #3 |
12-10-2014, 04:58 PM | #4 |
Last edited by LockDoc; 12-11-2014 at 11:03 AM. Reason: Can't post a "WIW" unless you are a premium member. |
12-10-2014, 05:00 PM | #5 |
12-10-2014, 05:02 PM | #6 |
12-10-2014, 05:18 PM | #7 |
12-10-2014, 05:40 PM | #8 |
12-10-2014, 05:35 PM | #9 |
Sweet looking burb, bet that straight six fires right up. Even when they are old, rusty and beat up those chevy's still look good.
12-12-2014, 11:53 AM | #10 |
Love that grill guard, Why the frame swap?, All the running gear should bolt in I would think, besides the offset 292 mounts.
12-13-2014, 02:22 PM | #11 |
Strongman Garage
That grill guard is sweet!
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
12-16-2014, 04:46 AM | #12 |
The 78 already has a beef tubular engine crossmember, beefier frame, reinforced steering box area longer springs,(all the fuel and brake lines are rotted on the 68)power brakes. What's a few body mounts..........
12-16-2014, 04:52 AM | #13 |
The previous owner said the bumper was original, but I have a hard time beliving that with all the dents in this rig. Although the grille guard may be rusty, it's straight. I will be tossing that in the pile of unused stuff, I have 2 other winch bumpers that I am going to test fit and see if I don't have to fab one. The old warn on my 78 would fit but it's not strong enough for what I am going to use it for. |
12-16-2014, 04:54 AM | #14 |
Burbalicious..
12-16-2014, 05:06 AM | #15 |
That sum ***** was dirty, and she pretty much looks the same. Except I can see the rot now.
12-16-2014, 05:21 AM | #16 |
sorry about the language, I'll keep it down.
So in my blind awe when buying this I failed to see the rot before I purchased. I still would have bought it, it just sucks that I missed seeing it. Hey, it was dark, raining, and I had been sitting in traffic for hour and a half more than I expected. I had a itchy trigger finger. |
12-16-2014, 01:45 PM | #17 |
That thing is shot ......... Looks worst than my green burb ! I might have another tub I might sell on the cheap.
12-16-2014, 02:19 PM | #18 |
12-16-2014, 04:16 PM | #19 |
I would get it running and put a reliable heater in it. Then drive it for a few thousand miles and see how the body holds up. If the body mounts are shot and the floors are real bad it might not be worth saving.
Look for a G86 on the glove box door. I think that denotes a Detroit locker. with a little work you can install power steering, and power brakes and even put front discs on the closed knuckle front axle. I would be inclined to keep that six if it is a 292. Is the Rockwell married to the SM420? The only draw back to the Rockwell is parts availability. The rear intermediate shaft bearing retainer is aluminum as I recall and I wore one out. It was tough to find a replacement. |
12-23-2014, 03:31 PM | #20 | |
Actually it's not too bad underneath. I only have one mount that might give me a problem. Pass Front Driver Front Pass mid ship Driver mid ship The rears look to be just as good as the rest. As far as the rear locker. I can't read the tag, it is too damaged. It doesn't really matter to me, I guess it could matter to the next guy. I will inspect it before I part with it. Power steering and power brakes will come with the other chassis. I am not even going to bother with the closed knuckle/drum brake dana 44, I got a dana 60 that's going to take it's place. My bad, it's a 465/rockwell combo. Not going to use that either. I have a 465 to a twin sticked 205. The plan is to eventually run a auto with a 203/205 combo. |
12-23-2014, 03:36 PM | #21 |
Just made the call for the steel for the rocker/floor replacement. Looks like some 2"x6" .250wall is finding a home there as rock sliders.
Cheaper than replacement panels that are just going to get ruined anyway. |
12-16-2014, 05:37 PM | #22 |
I have no plans to use any of the drivetrain. Not even the frame. It will eventually find a good home, somewhere else.
It's a 292ci 6cyl, sm465, Rockwell t-case. Closed knuckle Dana 44, Eaton Rear. |
12-22-2014, 11:51 AM | #23 |
If my recollection is correct the 68 is on a 127" WB and the 73-91 Suburbans are 129". Not a big difference, but something to consider.
12-23-2014, 03:00 PM | #24 |
No updates yet. Just a ton a rain. I emptied this can nov 16th and this is a shot from how full it was last week. It has since filled up more.
We really needed the rain. |
12-23-2014, 03:38 PM | #25 |
So the real issue that is still bothering me is the upper windshield piece. Do I have to cut this piece out of a existing truck or do they make a replacement panel for that?
