![]() Join Date: Apr 2011
Cummins swap into 65 C10??
Have been looking through pages and pages and haven't located any info or pics of anyone who has done the swap
I feel sure several have installed the 5.9 into a 60 model truck and was looking for advice or feedback before I commit to it myself.. thanks guys |
![]() Join Date: May 2010
Re: Cummins swap into 65 C10??
Try in the diesel sub forum. Good luck http://67-72chevytrucks.com/vboard/f...play.php?f=240
It only has original paint once |
Currently buttoning up a 4 cylinder swap.
60-66 Nut
I believe the 6BT will require some serious firewall modification. There are a thread here somewhere where a member is installing a 6BT into his C30 panel.
#5 | |
That would be me ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=523009 The 6bt is a tough fit. It does require a lot of firewall modification. Plus IMO the 6bt is too heavy for a stock C10. I feel that 1 ton (C30) suspension is almost a must for the 6bt. However a 4bt should fit nicely and work well with a C10. From what I understand the 4bt does not need any firewall modification. Just my .02 cents worth. Also here is a link to another thread asking the same question for his 62 http://67-72chevytrucks.com/vboard/s...d.php?t=687424
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue. http://67-72chevytrucks.com/vboard/s...d.php?t=523009 Last edited by spacedebris; 12-25-2015 at 12:58 AM. |
