03-26-2017, 06:03 PM | #1 |
1946 chevy truck build.
i have a 1946 chevy truck. my plans are 4 link in rear. ifs front end swap. v8 swap. and bagged almost to floor boards while keeping patina look.
ive been looking all over and havent come across anyone that has a build page of them doing this to one of these trucks just few pictures of some already done. already have a donor motor taken down to block and in machine shop getting hot tanked. waiting for the block back and all the new parts for the motor. after sittting for over 20 years only a small amount of rust on driver fender nothing to big or crazy though Last edited by dillonv2008; 03-26-2017 at 06:16 PM. |
03-26-2017, 06:13 PM | #2 |
Re: 1946 chevy truck build.
03-27-2017, 04:07 AM | #3 |
Looks like a good start...joedoh may try to take it away from you..he seems to be hoarding trucks these days..haha
03-27-2017, 10:59 PM | #4 |
SAVING ONE TRUCK AT A TIME
check out my build page. Good luck.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
03-27-2017, 11:01 PM | #5 |
man I need a nice donor like this to start with. all of mine are 40% iron oxide.
04-24-2017, 11:41 AM | #6 |
Sorry for the late update just got done rebuilding the motor for this guy came out pretty good next weekend I'll fire it up hopefully a smooth break in
06-24-2017, 05:22 AM | #7 |
dude Chizzler I gotta to see that truck in person one day..
I'm just seeing this post for the first time for some reason, sounds like the makings of a great build. Any other photos so far? |
06-24-2017, 11:42 AM | #8 |
Non so far I've been busy working and remodeling are new house maybe in another month I'll be able to work on it. But I have oreded and have rims and tires. Crags 69 with 2.38 white wall tires. Ifs m2 with air bags, 4 link for rear, air line and air bag parts. I have almost all the parts to do full suspension just don't have the time right now. Very soon though I'll be getting into it I hope..
08-26-2017, 11:28 AM | #9 |
Update. I've removed old engine and have started the ifs install
09-16-2017, 11:32 PM | #10 |
Need some help. I feel my 4 link is getting too much pinion angle change.
Ride height is 6.5 inches off the ground have it set at +3 for pinion angle. When aired down goes all the way too -6 degrees and i believe around +1 or 0 aird all the way. What did I do wronf?? My lowered are parallel with floor. My uppers are -3 , IC being at firewall. Lower bars are 21 inches bars alone. Uppers. 13 bars alone. Need some help figuring out why this is getting so much pinion angle change |
09-17-2017, 03:27 PM | #11 |
your uppers are not 13 inches long measured along the frame, only measured along the bar itself. my guess is they are 9-10 inches long measured in the same plane as the lowers. your forward attachment point is less than halfway along the lower, you are going to have lots of pinion angle change. you will also probably notice the axle moves forward in the wheel arch quite a bit when aired out too.
this is why I recommend tacking the suspension together and running it up and down a few times, like you have. good work. you should probably get longer uppers or reduce the angle on them to make them longer in relation to the lowers, because even if you resign yourself to driving only at drive height and accepting the pinion angle change as it gets lower, you need to be aware of something called "rear steer". measure from the axle centerline to a fixed point on the frame, then jack up just one side of the axle (like if the wheel was going over a bump) on the side you have jacked up you will notice the measurement gets shorter and the opposite side (which is pushed down) will get longer. this steers the truck from the rear suspension and is a way to have some crazy handling characteristics in corners. steering force applied at the end of the chassis is more unsettling than forces applied closer to the center of gravity (imagine a shipping container on grass. push in the middle and it probably wont move, push at the ends and you will be able to spin the container) looks really nice so far!
09-17-2017, 07:24 PM | #12 |
if your bar measurement of 13" was related to the bar measurement of the lowers as 21", you still have the problem. measuring eye to eye isnt going to make it better. fix these problems:
your upper bars point down while the longer lowers are straight, this will always cause pinion/roll steer problems. you want them to be close to level when at ride height. your upper bars are way too short. looking at them from the top this is visible, the upper length looks to be less than half the lower length. you can only measure their length STRAIGHT ALONG THE FRAME, it doesnt really matter what the actual length of the bar is. the effective length, measured straight along the frame, that is how long the bar is. not eye to eye, not just the bar length, all of that is irrelevant. mark two spots on the frame, the centerline of the axle and where the upper bar attaches to the frame and measure straight between those two points. that is the length of your upper bar. if it helps, imagine it as a big rectangular piece of steel instead of an angled bar. even though you can draw a long line from corner to corner of the rectangle, how long the rectangle is measured along one side is how long the rectangle is. thats it. the upper arc of operation will be a much smaller diameter circle than the lower arc of operation, so the lower mount will stay roughly stable in up/down motion while the upper will not, it will move forward and back dramatically. having the lower bar mount kicked forward of the axle centerline is pretty standard for 4 links, especially with a shock mount on the rear. edit: I just rotated and enlarged your picture so I could see better and it looks like you are welding to the cast part of the rearend. this will probably break under use, welding to cast is possible if you preheat it with a torch and get it cherry red but it takes special rod too.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 Last edited by joedoh; 09-17-2017 at 07:37 PM. |
09-17-2017, 08:13 PM | #13 | |
I understood what you mean. Not length of the actual bar but from centerline axle along frame rail to the link where it attached to the frame. That was indeed 13inchs. I was just saying the specs of the bar itself in post about length of lower and upper bar actual spec length. But I removed the upper bars and going to be re angling them around 30sih degrees or so and parallel with lower bars at ride height. I'm ordering new tab links because old ones didn't make the tear down haha. So when New ones come in I'll go ahead and do what you said. Also I'll mount them on the axle them self not the pumpkin part as you are saying can't be done unless special measures are taken. Would I get a better pinion angle stability of staying still if I was to just do a reverse 4 link? And order longer upper bars?? Or if I do what you are saying of pushing angles not so wide and level I will see a much better and practical ride. I want to be able to drive at it slammed for shows or streets. So all angles id like no issues with driveline u joints going out |
09-17-2017, 08:15 PM | #14 | |
09-17-2017, 08:43 PM | #15 | |
09-17-2017, 10:11 PM | #16 | |
nope you got it. look from the side and that is the length that matters.
09-17-2017, 10:43 PM | #17 |
[QUOTE=joedoh;8041849]nope you got it. look from the side and that is
Awesome thank you so much |
09-18-2017, 12:24 AM | #18 | |
I do understand you want it to be opposite. -3 tranny +3 axle yatta yatta yatta. So if my axle at ride height is as high or higher then transmission angle am I still going +?? |
09-22-2017, 04:34 PM | #19 |
Hi, I am going down a similar route so this thread is interesting. If you wanted to make the side view equal length then the top bar would have to be longer than the bottom bar? Is there an acceptable ratio to aim for or is it just to keep the pinion change to a minimum over the suspension travel?
09-24-2017, 07:26 PM | #20 |
one more question just got the new upper bars in when I go to do the measureing from side view and upper bars need to be the 70 - 80% range. when measuring lower bars length. my lower tab as we talked sticks them forward because they are the shock mount style. question is do I measuring from center axle to front bar link to get my measurement or do I just measure link to link. my lower axle link is forward a few inches from axle.
09-24-2017, 08:24 PM | #21 |
[QUOTE=joedoh;8041759]if your bar measurement of 13" was related to the bar measurement of the lowers as 21", you still have the problem. measuring eye to eye isnt going to make it better. fix these problems:
your upper bars point down while the longer lowers are straight, this will always cause pinion/roll steer problems. you want them to be close to level when at ride height. your upper bars are way too short. looking at them from the top this is visible, the upper length looks to be less than half the lower length. you can only measure their length STRAIGHT ALONG THE FRAME, it doesnt really matter what the actual length of the bar is. the effective length, measured straight along the frame, that is how long the bar is. not eye to eye, not just the bar length, all of that is irrelevant. mark two spots on the frame, the centerline of the axle and where the upper bar attaches to the frame and measure straight between those two points. that is the length of your upper bar. if it helps, imagine it as a big rectangular piece of steel instead of an angled bar. even though you can draw a long line from corner to corner of the rectangle, how long the rectangle is measured along one side is how long the rectangle is. thats it. nvm I reread this and understand center of axle to center link on axle |
09-25-2017, 12:37 AM | #22 |
Great progress tonight have front all tacted in place and rear tacted in with only maybe 1 degree change from ride height to on the ground about 6.5 inch of travel
09-29-2017, 10:34 PM | #23 |
the unequal length is what allows the stability of pinion angle without fore/aft movement.
if you do what I said above, about mocking it up with paper, use pins as the pivots, you will easily answer these questions for yourself. in engineering we have a saying: "engineers will argue for an hour about something that could be tested in 5 minutes" mock it up with paper, you will be able to simulate longer bars, different attaching points, unequal bars, pinched bars, all of it. literally a 5 minute test. better than that, you will see it for yourself, way better than trying to interpret words on a screen
09-29-2017, 10:54 PM | #24 |
[QUOTE=joedoh;8050799]the unequal length is what allows the stability of pinion angle without fore/aft movement.
if you do what I said above, about mocking it up with paper, use pins as the pivots, you will easily answer these questions for yourself. in engineering we have a saying: "engineers will argue for an hour about something that could be tested in 5 minutes" mock it up with paper, you will be able to simulate longer bars, different attaching points, unequal bars, pinched bars, all of it. literally a 5 minute test. better than that, you will see it for yourself, way better than trying to interpret words on a True after your help with first part my pinion angle is perfect and everything so I Don't think I'm gonna confuse my self on this. I'll just angle the upper bars further out on axle and in on driveline tunnel. And bring in lower bars so I can run bar on bag. Switching upper bars angles so I can have room to center bags on bars. |
09-29-2017, 11:36 PM | #25 | |
but when bars where parallel it didn't seem like pinion angle changed at all?? |
