Help Me Pick Some Heads For Christmas Present
So with Christmas just around the corner I wanted to use the opportunity to pick up some heads for my son's '73 project truck as a surprise. He's been working hard to pay for parts on his own to this point so a little bit of help from Dad isn't a bad thing this time.
The engine is the original rebuilt sbc 350 5.7L with the following mods: - Comp Cams Xtreme Energy Cam & Lifter Kit (11/2010): Summit# CCA-K12-238-2; Cam/Lifter, Valvetrain(timing chain, sprockets, springs, valve stem seals, etc.), Hydraulic Flat Tappet, Advertised Duration 262int/270exh (Actual duration at 050” lift: 218/224), Lift .462int/.469exh. (Stock 350 SBC Cam Spec-estimated: dur @ .050 on that cam is 195/202) - 1406 EB carb & Performer EPS manifold - Full length headers, 2.25" exhaust with flowmaster mufflers - 3.08 gearing Basically I'm looking to increase low end torque and bump the hp a bit so I'd like to replace the stock heads with something but I just don't know what all of my options are so I'd like to get some direction from you guys. With a budget approach in mind, should I get... 1. Rebuild 062 Vortec heads on ebay (~$175/head but I have to send back cores which I don't have so I'm not sure what the extra cost will be here) 2. Summit Vortec heads like this: https://www.summitracing.com/parts/sum-151124 3. Corvette Heads (which are best?) 4. Another option? Ideally I'd like to utilize the components we currently have. Last edited by Nuckingfuts; 11-23-2017 at 02:44 AM. |
![]() Join Date: Oct 2011
Re: Help Me Pick Some Heads For Christmas Present
If you change to Vortec heads, which are a very good head....you will also need a new matching Vortec intake to go with it.
As well, you will need to check and see what else changes in terms of all your mounting bracketry...particularly if you have (stock) a/c brackets, etc. The exhaust bolts right up I believe....but I'm not sure about the other brackets that are dependent on the factory mount locations. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Corvette heads?....do you mean original GM 'period' corvette heads?
If so, the heads you would be after would be a '186' casting or an '041' casting....and they have all the correct mount/accessory holes in them for the truck bracketry. '461' heads won't work in a truck application with a complete 'redo' of the brackets to an older style. These are a direct interchange with your stock heads but offer better flow (not as good as vortec) and slightly raised compression due to their 64cc (vs. 76cc) combustion chamber. The trick is to find a good set that you can buy and bolt on. What is your realistic budget for all of this?...that is an important driving question. $1000? $1200? $1500?.....$800? $500? or Coley
#4 | |
I've heard others here (i.e. Marv) speak of options that dont require new intake, self aligning rockers, etc (that the Vortecs require) so I'm definitely interested in hearing more on this point as it might help me keep the cost down and within budget. |
60-66 Nut
Since you already have an intake, I would stay with a head that is designed for the typical 12 bolt intake. If you click on the link you posted on Summit for their Vortec heads, go to the upper right where it says 'View Similar Parts' and click on 'cylinder heads' You will see many choices to choose from. I would stay with a head that has no more than 180cc intake ports.
#6 | |
#7 | |
I guess what I was hoping is that there is a solid performing head out there that will give me a good bump of torque down low, work with my current cam, and allow me to use my manifold and most other parts. Maybe I'm asking too much for a $1000 budget, I just don't know at this point. |
#9 | |
#10 | |
https://www.ebay.com/itm/Elgin-Engin...pZ-MMG&vxp=mtr |
#11 | |
Let me ask a few follow up questions comparing the Summit Heads linked above (SUM-151124) vs. the ebay linked EngineQuest Heads: 1. Made in USA vs. New Zealand, quality concerns/differences to be aware of? 2. Performance between the two expected to be relatively equal? 3. Summit heads require some machining to accommodate guide plates, is it safe to assume that I don't need to machine or install guide plates if I am using self-aligning rockers? As far as the economics compare: Option 1: Summit Heads $700/pr Summit Manifold SUM-226018 $160 Self-aligning Rockers $70 Head Bolts $70 Valve covers ~$100 Misc Fel-pro gaskets $50 TOTAL= $1150 Option 2: EngineQuest Heads $740 Self-aligning Rockers $70 Misc Fel-pro gaskets $50 TOTAL= $860 Am I missing any questions or parts/machining costs? |
#12 | |||
"I ain't nobody, dork."
![]() Gary
Now that seems like a good deal..
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Maybe look here.
http://www.aeroheadracing.com/chevy.html |
#15 | |
#16 |
Hot Rod used Enginequest heads in Budget Sledgehammer
http://www.hotrod.com/articles/0611e...c-small-block/ |
#17 |
Performance should be near equal
Never heard of any problems with the enginequest heads No guide plate needed these heads may weigh a few pounds more due to the thicker decks and heavier casting |
#18 |
I sure appreciate you (and the other members here) taking the time to answer my questions and help with suggestions. Looks like I've some parts to order this week.
#19 |
When these heads come in, is there any fine tuning I will want to do to get the most out of them? Port work, upgrade seals, etc?
#20 |
IMO since you are doing the heads for a little better power, and not all out power, I would run them as-is
#21 |
Well I've been doing some reading up this morning (actually a lot of it and my eyes are bleeding) on these EQ CH350H heads and I'm concerned with what I'm hearing across all the builder websites that have users with direct experience with them.
In a nutshell, the hybrid style vortec head (i.e. EQ CH350H) has lower flow numbers (when compared to 062s, Darts, etc.) as a result of having to accommodate the old style intake location/size. My understanding is that this is enough of a departure from the raised vortec style head design that engine performance suffers. Lots of praise for the EQ heads in general which is really encouraging though. Last edited by Nuckingfuts; 11-25-2017 at 05:44 PM. |
#22 |
Couple follow up questions:
1. Can I use my stock pushrods with the vortec style head and self-aligning rockers or do I need a different length and/or hardened? (I'm assuming 0.040" quench) 2. Do I need to widen the pushrod hole when using self-aligning rockers? 3. Can I re-use my original head bolts or do I need to get newer style head bolts that use the torque+angle method? |
#23 |
Fabricate till you "puke"
Brodix 180, brand new in my area (not mine)....check craigs list East moline Il. he says 925.00, pick up. On the left coast, you are a long ways out, but it sounds like a smokin deal! They should work well with the kids truck/cam ect. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#24 |
Yeah, that's going to be out of reach for west coast shipping costs. Those Brodix 180's have a good rep? Never heard of them before but will look into them in the event I find a deal closer to me. Thanks for the tip!
#25 | |
60-66 Nut
1) The Vortec heads do not require a different length pushrod. The L31 Vortec engine uses the factory roller cam, which requires a shorter pushrod. It is always a good idea to check your engine assembly for the correct length pushrod. You do not need hardened pushrods when not using guide plates.
2) If this is oin reference to the Vortec heads, no you do not need to do anything with the pushrod slot unless you are running 1.6 rockers. The L31 Vortec engine came from the factory with self-aligning rockers. 3) Yes you can use your original head bolts as long as they are in good condition. However new head bolts is good insurance against a failure. Quote:
