Have a 74 K20 frame and springs and I got Alcan springs From ORD w/a 2" lift as advised to get a softer ride and all there stuff like super shakles and hangers and lubed bolts,poly bushings and every thing else they had for springs. 3K later practically no change. I have Rancho 9000 shocks on there now and had to move the rear perch down so they would even fit. So.. I am thinking of getting the correct length Bilstien shocks. Here's the thing: There are 2 rates of these shocks 255/70 and 170/60. the higher rate is suggested as normal and the lower for dual shocks. I'm still looking for a softer ride an wondering what would be the result of my installing the lesser rate shocks 170/60,what do you think??? What's another 400 bucks anyway. In for a dollar in for a dime.
Re: Bilstien shock experiment $$
Why didn't you get the matching bilstiens from ord? Catalog bilstiens aren't the same as what has been picked by ord. Call them and buy them from ord. I have **** springs with those shocks and it's remarkably better.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2 1991 V3500 350/4l80/205 60/14 4.10 35 toyos. |
ORD really dropped the ball on this one. I do not trust them or any advice they may give me. You want me to go into it?? I doubt that the forum would post it. Answer my Question !!!!
just go to ord and get there shocks to match .
and its dever spring and alcan is the ones ord has build them if i recall correctly .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#6 | |
whats the problem ? ? lots of guys running them and super happy over on ck5.com site . unless you changed something or didnt give the right info they should be spot on . and yes rancho shocks fit like crap . i recently worked on a guys truck and the rancho shock part#'s were correct for his truck and lift hight . but the shocks were limiting spring travel by close to 25% . made for a hard ride . told him but he didnt care .. . . .
#7 | |
Sorry to hear about your experience but there isn't a doubt that ord chosen bilstiens are the best option.
ORD has never done me wrong. Must be a problem on your end
![]() My Bilstiens ride mint Last edited by the_ocho; 03-08-2018 at 09:09 PM. |
I don't have a problem with my truck. I call ORD and talk about what I want. Give them money, they give me parts. I bolt them on. All is well
![]() Well one time UPS lost a box of parts, that was a problem. But ORD replaced the Parts. |
Maybe the OP needs to link his truck?
![]() Join Date: Dec 2009
AKA- brans87 on CK5.com
I have bought parts from ORD with no problems from shackles,bushings,shocks shock mounts etc. I would really like to have there springs but not in my budget. Maybe you should post up pics of your suspension setup and let some of the guy's help you get it correct!!! There are way to many CK5.com member's that can back up ORD is top notch stuff and they know what there doing. So before you get carried away there Simply post some pics up. It will only benefit you in getting your truck right!!!!! |
There are so many things mixed up here. You could have avoided all of this by contacting bilstien and asking your simple yes or no question. But now your truck specs are all wonky and completely overcomplicated. Sounds like ord has offered to help and fix this pretty well. It seems like even if you get the correct shocks you probably won't be happy because you messed with everything in really strange ways.
This is a very simple system. ord is only as good as the information they are given. And there are many of us with the same stuff and no problems.
#15 | |
#16 | |
How about some pictures? Posted via Mobile Device |
#17 |
#18 | |
But in all seriousness I have probably built hundreds of these trucks professionally and for myself. Your information just doesn't make any sense.
#19 |
Bilstien has shocks fir that application too
I’d recommend ORD Posted via Mobile Device |
#20 |
#21 | |
ORD as done a lot for the GM and offroad community, something went wrong with your situation but there is no need to be rude to the only company that will help you. Some things cant be left alone. |
#22 |
Can you post pictures of what this looks like now? I think above it was mentioned to move the hangers back 4" (from the 52" to 56" spot) but then something was said about moving the shocks 4" down - wonder if the wrong mounts are getting moved around? Seems like there is a lot of confusion and misunderstanding going on. Pictures may help with clearing up what is going on. 7" lift seems pretty far from the mark if you ordered 2" lift springs. I dont have any lift springs, and never worked with ORD either, but pictures may be able to help clear some stuff up. I'd hate to see you keep throwing money at something that it sounds like you may not fully understand.
#23 |
Again asking for pictures your not will to post up but your willing to bash ORD!!! No one is going to judge your truck!
There only trying to help you out and that takes a picture to see exactly what is going on with it! ORD doesn't need to put people up against you as you claim! There is a Brotherhood that stands behind ORD quality and technical experience in the off road world!!!! Be alot easier if you would just post some pictures up so you can move along with getting your truck right. |
#24 | |
#25 |
K5Camper
![]() Join Date: Mar 2004
Something don't add up in your combo. 2" springs with a shackle flip would net 6" normally. The fact that you indicated you moved the shock mount down on the frame so they would reach would be a pretty clear red flag that the shocks are too short for the spring combination.
Mixing and matching gets very challenging with this stuff. ORD's combinations are proven. Watson is known throughout the industry for his specific squarebody suspension products. He's done the R&D with his own stuff. A picture is totally worth a thousand words here. I'm pretty sure once the pics are up the problem should be able to be figured out.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
