Manual to Hydro Clutch Pedal Linkage Question
Who has converted their manual clutch to hydraulic clutch? What did you do for pedal linkage? Recently swapped my '61 235 for a 250 and set it up with a Novak slave cylinder kit and Wildood master as I converted to disc and got rid of the single reservoir system. Having trouble coming up with something to get from my clutch pedal arm to the MC all while keeping correct geometry. Thanks in advance.
![]() Join Date: Sep 2016
Re: Manual to Hydro Clutch Pedal Linkage Question
Captain Fab has a great setup! Works great.
I used Cpt coversion.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Thanks for those pictures. Does he sell the pedal linkage as well? I know he makes the master cylinder mount kits when using a brake booster.
Here is the link to 60-62.
http://www.67-72chevytrucks.com/vboa...d.php?t=362375 |
This is a novak setup on the 283
![]() Join Date: Mar 2011
I used a '63 brake master cylinder and a '62 slave cyl on a bracket from A/A, (both 1" bore) and a pedal assembly from a '62 to convert my '63 to hydroboost and hydraulic clutch.
63 k20 with cummins 4bt, owned sence 1982 Last edited by dieseldude4bt; 04-16-2018 at 04:44 PM. |
