Active Member
![]() Join Date: Oct 2017
Quadrajet help
I have an issue with my 1969 Chevrolet C20. It has the 350 V8 with the automatic transmission, the carb is the Rochester Quadrajet. The truck starts up fine, comes to a idle after a few minutes. The problem that is occurring is that after driving for 15 mins or so, you come to a stop and the truck wants to die. The truck has 88,000 miles and I'm guessing that the carb is original. Any thoughts....adjustments or rebuild ?
Thanks! |
Re: Quadrajet help
Is it running out of fuel? I think those had a filter at the inlet, might check it. Quadrajets are good.....when they work
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
![]() Join Date: Apr 2016
Re: Quadrajet help
Sounds similar to the problem I had
http://67-72chevytrucks.com/vboard/s...d.php?t=760430 |
Active Member
Re: Quadrajet help
Yes, gas filter was replaced.
Re: Quadrajet help
Check for a vacuum leak.
Is this a recent occurrence or has it been ongoing? |
Active Member
Re: Quadrajet help
It just started... just had some work done to the truck - new exhaust, hoses, belts and brake lines.
Re: Quadrajet help
www.cliffshighperformance.com
You need a rebuild. Cliff can sell you a kit and all the parts to calibrate your carb for todays gas, and his parts are ethanol resistant. His stuff isn't cheap, but it IS the best!!! Get his book ,also! |
Re: Quadrajet help
Yes you might need a rebuild but find the source first. You might be chasing it after a rebuild too.
When you say it comes to an idle after a few minutes, is that from you kicking the high idle off? And when it does that is the choke completely off? |
Active Member
Re: Quadrajet help
Yes, after a few minutes, I'll tap / kick the accelerator to bring the engine to an idle....I'll have to look later today regarding the choke...
Thanks! |
#10 | |
Re: Quadrajet help
Here’s a pic on a link. https://www.google.com/search?tbm=is...d5PpmhDXHRHTM: |
![]() Join Date: Oct 2011
Re: Quadrajet help
It does sound like something in the choke circuit (passenger side of carb) is off somehow.
When they did the work on the truck, did they touch the timing? I'll take a page from Geezer's book and say check that first to make sure you have (at least) 8°..personally I would recommend 10-12° to start. Regardless, make sure the choke equipment is working properly....check all carb hoses as well...or simply replace them (they are cheap). These include the main hose up to the power brake booster, the PCV valve, the short air cleaner connection, the vacuum advance hose, and even the little short one between the choke pull off and the carb. Also check the transmission vacuum hose which comes down from the upper manifold to the trans. When the truck is idling...is it smooth? or does it sound a little rough? ...if it not a smooth idle, all cylinders hitting...then you probably have a vacuum leak. Do you have any pics of your set up? Coley ![]()
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
Active Member
Re: Quadrajet help
Nothing was touch regarding the engine... the truck runs smooth on all cylinders...here are some pic:
Re: Quadrajet help
Nice pics!
I can see your choke plate wide open but the lockout tang is still hooked on the secondary pin. Could just be some crud on the tang. I’d spray it and clean the whole choke area with some carb/choke cleaner first. Then if that doesn’t help we can help you with a couple more possible things to check. |
Active Member
Re: Quadrajet help
Thanks again.... will give it a try
#15 |
Active Member
Re: Quadrajet help
Just an update, I did clean up the carburetor and gave the truck a run later that day...... so far so good...
Will keep you all posted Thanks ! |
#16 |
Active Member
Re: Quadrajet help
I thought I was all set with the idling issue, but it's back. Took it out over the weekend, about 10 mins into the drive while at a stop light, it felt like it was going to stall out, so I place it in neutral until the light change. Not sure on what to check next...
Any suggestions....Thx ! |
#17 |
Who Changed This?
![]() Join Date: Jan 2013
Re: Quadrajet help
Spray carb cleaner around the primary throttle shaft on the driver's side and see if the idle speed changes. You likely have a worn bore where the throttle shaft goes through the base plate. If there is a vacuum leak there, it will be covered up by the richer mixture when it is on the choke.
#18 | |
Re: Quadrajet help
What’s your initial timing set at? |
#19 |
Re: Quadrajet help
No wonder it dies!
Bump your initial up to 12. You’ll see a world of difference. |
#20 |
Active Member
Re: Quadrajet help
Thanks for your input geezer ! I'll post results tomorrow.
Steve |
#21 |
Active Member
Re: Quadrajet help
Set timing at 12.....went for a drive.... no issues !
Thanks again ! |
#22 |
Re: Quadrajet help
Good deal!
#23 |
Active Member
Re: Quadrajet help
Just an update... last month while driving to work, had the idling issue come back again.... I was going up a hill, accelerated to get up over the hill, came to a intersection and the truck wanted to stall out. Talked with my mechanic about it and he mention that it could be the accelerator pump - so at that point, decided to go ahead and rebuild the carburetor ( the truck has 88000 miles and the carb appear to be untouched) . The carb is back on the truck, no vacuum leaks, timing is around 12. The truck starts up and runs great for the first 10 to 15 mins into the drive, then I noticed the idle has come down again....not sure to look at next.... it does have a HEI that was installed by the previous owner - could this be an issue ? Very frustrating... like I mention, she runs great at the start, but something is happening once the engine get's hot.
Thanks guys.... I appreciate any input ! Steve |
#24 |
Re: Quadrajet help
You are supposed to do the tuning such as setting the idle speed when the engine is fully warmed up. So go ahead and get it warmed up, make sure the choke is fully open, and then adjust your idle speed and mixture screws if necessary, for smooth idle. Idle should be about 600 to 700 while in drive with parking brake set and wheels chocked and you standing to the side making the adjustment. Then see how it does the next day. When the engine is cold and choke is active it should idle faster, there is a fast idle adjustment screw tied to the choke.
#25 |
Active Member
Re: Quadrajet help
Ok.... we'll give it a try.....
Thanks |
