Door jamb striker nut gone/missing?
My cab is an 87. It was mostly stripped down when I painted it nearly 20 years ago so I can't remember all the details.
So my jamb has a rectangular opening with nothing behind it for the striker to thread in to. It doesn't appears anything was torn/broken away from the backside of the cab. Its the same on both sides. Ive searched around and it appears there was a cage nut that was maybe welded in place originally? I don't want to weld anything at this point as everything is painted. Has anyone just used a large washer and nut on the backside to mount their striker? I imagine the cage nut had some movement in it anyway so using a nut shouldn't be much different. Thanks in advance.
'78 C10 Build |
![]() Join Date: Oct 2014
Re: Door jamb striker nut gone/missing?
Search for it behind the panel, behind the rear speaker. The striker nut is not welded, so once the striker is removed, it will fall to the floor in between the panels.
I found this out when I put new striker bolts on my truck. I about sh!t, when I heard it fall. I was thinking it would be between the panels and I would not be able to retrieve it. But it was laying back behind the speaker.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
![]() Join Date: Mar 2003
^^yup that happened to the first time also. Heart kinda sinks the first time you hear that fall to the floor inside the pillar
Thanks guys. Unfortunately if they fell and I removed them I can't find them at this point in the build. Is there anything special to it? I don't see anything that would keep it from turning even if it was in a cage. At this point I figure a nut and washer will serve the same purpose.
'78 C10 Build |
Since your in Columbus, run to the Pick-N-Pull, they have a truck in there you can get them from. I was just there last week, when the truck came in. I went and grabbed the seat. It's out in Row 73.
It's square piece of metal with the hole in the center the threads push out the back 1/4 " about
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
I found the nuts I was needing. Thanks everyone for the tips.
'78 C10 Build |
Yep, that's it.
