Gray wire from fuse box
Where does this gray wire from “cluster” go to? As you can tell by picture it was frayed and hanging.
Posted via Mobile Device |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Gray wire from fuse box
See my reply in the other forum.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Msgt USAF Ret
Sorry I apologize. I usually try to reply to other members as well as the original poster. The gray wire runs from the PNL LTS fuse on the fuse panel to the cluster plug to terminal 8 on gauge panels and to terminal 12 on idiot light panels. It joins with the heater lights panel wire on those two terminals. This diagram shows the wire via the blue arrows.
Ok. I have wire all undone. From cluster plug.... two wires. One goes to back of fuse box. The other goes to heater bulb. I still can not find where gray wire that plugs in the face of the fuse box like the picture I took above.
Msgt USAF Ret
You will need to pull the fuse panel away from the firewall by removing the two diagonal screws that hold it in place. Look on the back of the panel for a dark green wire that runs to the pnl lts fuse. The gray wire should be on the other side of the fuse that the dk green wire is attached to. The dk green wire comes from the headlight switch rheostat (dimmer switch) to the fuse panel and is the feed wire for the dash lights. The gray wire should be attached there and it runs to the terminals I mentioned in my post above.
Hello Team,
i have a 72 K5 with the same fuse box and i can't tell what fuse amps are. can you share what yours shows as i have the same fuse box? i just need to know what those fuse numbers are so i don't put i higher number and blow something up ![]() |
Msgt USAF Ret
Here's a couple of pictures and some of them are a little hard to tell which amps are for which position. If you cant' decide which just post back.
The first pic is perfect, it shows info i needed. i didn't know they use 3As i'm glad i asked otherwise i would had put in 15 or 20s.
Thanks VetteVet |
